1channel working ,but picture keeps freezing ?
  • tinbin
    • 138
    Another great plugin if only it would play without freezing,is there a more stable plugin that works Please.
  • gji25
    • Feb 2010
    • 353
    what plugin are you exactly talking about ?
    dm500hd -dm500hd v2-vu+duo- triax 1.1m - inverto lnb - technomate 2300 motor- linksys ddwrt router
    • tinbin
      • 138
      This is the version i am using m8, 1channel (nousb) 21 July 2012.
      • gji25
        • Feb 2010
        • 353
        ok im with you now.. i thought you meant 1 channel as in 1 specific channel . ok the reason why 1channel is freezing is all down to there server. it needs to have alot of work doing to it @ the moment.. just ping 1channel.ch and see whatsort of ping times your getting. it will probably be somewhere between 300ms and 1100ms. hence it needs some work done to it to get the ping time down
        • tinbin
          • 138
          Thank you very much for explaing what the problem is, I had it working perfectly on ViX-2.3.133.So lets hope that, they get it stable again.
