i have a vu duo clone v2 got it around a year ago replaced psu around 6months ago. it was working fine until few days ago and now the panel at front just says startting with a red led light. iv flahed several images via usb and also used a rs232 cable to flash them but no luck. also but bootlader via usb and flashed the v2 and v3 update and still doesnt work. iv tried everything possbile but cant get the damm thing to work. could someone help me out plz. thanks
VU DUO DEAD STUCK STARTING..... HELP
Check all the connections inside are pushed fully home. Also if you have a hdd fitted, disconnect it and try again.Comment
look for a thread about the red light saw one in the solo and duo sections basicly you might be able too fix it with the jtag style fix with involves buying a pcb and reflashing your your unit
edit
heck it was on the front page in section
Its the cable i got with the box and the module. I flashed thr firmware using vu uti and now i get starting on the display at front thats it. I have tried doing the secret update using the module provided but it isnt working. i think i may have killed the security chip thats why when i try to flash bootloader update it doesnt respondLast edited by asad5150; 10 March, 2013, 02:23.Comment
