i use the mounts manager to access my duo recordings from my solo or max digital 1000hd boxes,saves adding an external hdd to both,also going to try a network drive plugged into lan to rec to and maybe add movies or music.
as your enhancements are off,switching on should open up your settings,may need to save settings when .adjusted.
so any network device i can see
[QUOTE=cactikid;1876379]i use the mounts manager to access my duo recordings from my solo or max digital 1000hd boxes,saves adding an external hdd to both,also going to try a network drive plugged into lan to rec to and maybe add movies or music.
so any network device i can see[/QUOTE
