HD Channels to top in Favorites
  • KJ1Pete
    • Jan 2013
    • 30
    hi all
    A newby but just finished setting up my Vu+ duo with a Vix image.
    Its set up pretty much how I want it so I just need a few tweaks.
    1 I am going to install an internal hard drive, can I remove the harddrive from my old Sly HD box and fit that, - I assume if I format it to FAT32 it should work fine?
    2 How do you move the favorite channels I would like the HD Channels to be first in the favorites instead of at the end of the second page, is their an easy way to move it?
    Thanks in advance
  • DOUGALMCD
    • May 2011
    • 3229
    Hard drive fits fine but remember to mount and set path ie media hdd.
    When channel list is showing on screen press menu and this should show enable move mode.
    • septicsmurf
      • Feb 2012
      • 401
      Originally posted by KJ1Pete
      hi all
      Thanks in advance
      If you have the latest vix you can use auto bouquet maker as well, which you can configure to show hd channels first.
      Saves you having to update the channel list.
