help saving channels
  • genuine1
    • Jan 2012
    • 29
    going to try a different image on duo but want to back the channels up to save having to do a scan.
    how do i go about doing this please
  • scottj130208
    • Apr 2011
    • 323
    if your using blackhole try menu and blackhole backup you can backup to usb or you can back up bouquets ie channels using dreambox control centre which there are tuts on here have a look at the dreambox section good luck
    • genuine1
      • Jan 2012
      • 29
      im using vix but should be the same.using dcc already so will back up and give it a go.thanks
      • gji25
        • Feb 2010
        • 353
        you backup your channel listings using dbedit (dreambox edit) not dcc
        dm500hd -dm500hd v2-vu+duo- triax 1.1m - inverto lnb - technomate 2300 motor- linksys ddwrt router
