Help a newb flash my duo
  • NICETOBNICE
    • Nov 2011
    • 551
    Hi guys i have read loads on how to flash a duo with USB and how to put the files within the root but not having any success .
    I have flashed dreamboxs in the past 100s of times with nul modem cable and crossover but not sure what software or if its possible to flash a image this way
    i hope someone can help thanks in advance
  • Rodbouy
    • Jul 2010
    • 1320
    Just copy the unzipped vuplus folder to root of a usb stick,
    Plug in usb stick turn on and it will flash.
    Make sure the image you are flashing is safe for your box.
    You should have ver sticker on back if its a clone.
    • NICETOBNICE
      • Nov 2011
      • 551
      tried that mate and no luck its a v3 clone
      what software is needed to flash via cable
      • Rodbouy
        • Jul 2010
        • 1320
        HAs the box booted with the pre flashed image since you bought it?
        When you add the usb does it just boot right in to pre flashed image?
        You dont flash the image via null.
        • NICETOBNICE
          • Nov 2011
          • 551
          yes its working at the moment just not sure if i'm doing something wrong ?
          it displays on the lcd starting but nothing happens
          • DOUGALMCD
            • May 2011
            • 3229
            V3 version>The software you are looking for is the ferrari security update done via the cable once this is done you just load the latest images via usb.
            • NICETOBNICE
              • Nov 2011
              • 551
              Thanks mate that means nothing to me
              where do i get that ?
              its a V3 by the way
              • NICETOBNICE
                • Nov 2011
                • 551
                its a V3 by the way
                ok guys i've found this
                V3.2_upd_vu62k
                is that the correct file i need to run is there a program for flashing really dont want to brick my box
                • NICETOBNICE
                  • Nov 2011
                  • 551
                  OK that's that done
                  So now i can put an image onto a USB stick and the display says reading USB.
                  Then after a while it asks to unplug and reboot' but when i do it just says starting and nothing happens ?
                  • portbhoy
                    • 717
                    Have you got it connected to the tv? Is there anything on the tv display? Do you have a hard drive or other usb devices connected.
                    • NICETOBNICE
                      • Nov 2011
                      • 551
                      there is a hdd installed inside the box ?
                      • portbhoy
                        • 717
                        Ok can you disconnect the cables just now, turn it completely off first using the rear switch then try to boot it.
                        • NICETOBNICE
                          • Nov 2011
                          • 551
                          done that mate exactly the same what image should i use to try and get it up and running ?
                          • portbhoy
                            • 717
                            This is an older original image I use it when things go wrong
                            When it says remove usb turn off at rear remove usb wait about 30 seconds then turn on. Good luck.
                            • NICETOBNICE
                              • Nov 2011
                              • 551
                              Thanks mate tried that it flashed great .
                              waited for a few minutes then turned it back on and still saying starting ?
                              forgot to mention this i went onto the vuplushd website and it suggests installing VU DUO secret chip update 120229
                              so you can install new images i done that great on my pc with the rs232 so wondering if i have done something wrong
                              this is the website VU+ Duo
