USB DVB-T Tuner problem
  • athenrybhoy
    • Jul 2012
    • 76
    Digital TV HDTV DVB-T USB Stick Dongle Tuner Recorder Receiver - BuyinCoins.com.........cant get this tuner to work on vu duo,downloaded italysat dtt when i select driver it says "downloaded succesfully" but when i try to enable it says "cant find compatible usb tuner" on 1 version of italysat dtt ,on another version it says "driver downloaded succesfully" but when i try to enable it says "you must download driver first"......driver i am downloading is AverMedia Volar Black HD - AF9015... tuner works on pc so i know its working ....anybody got any ideas thanks in advance
  • athenrybhoy
    • Jul 2012
    • 76
    doh! just spotted this enigma 2 chat is in sat dreambox section will repost over in vu duo ,still cant see why it would'nt work once you have correct driver
    • digicon
      • 8261
      Moved to the correct section for you, what image are you using on the duo
      • athenrybhoy
        • Jul 2012
        • 76
        bh 1.7.9 on genuine duo
        • athenrybhoy
          • Jul 2012
          • 76
          sorry digicon did reply to your last post that has now disappeared , tuner was just a no name no box cheap as chips 1 delivered from china for 6 euro but it does work perfectly on pc.but as you said bh do have a lot of usb drivers already supported.... and if this quote from enigma 2 section is correct this should already be supported.
          Originally Posted by Fano
          I have this one working on my Dm800 under the Dream Elite Phoenix image .
          Its just over 5 euro delivered and uses the Afatech 9015 chipset which is the same as that in the Avermedia Volar tuner which costs over ?30.
          I cannot fault it so far.
          if anybody could recommend a good usb dvb-t stick that they have working for saorview channels preferably on bh.
          i would be grateful
          Last edited by athenrybhoy; 17 March, 2013, 18:56. Reason: extra digits appeared instead of ***8364; sign
