On demand
  • sabbacool
    • Feb 2013
    • 48
    On demand
    The feeds have been down for couple days now... Does anyone have the file for the on demand, or any idea when the feeds will be back up?
    Cheers
  • septicsmurf
    • Feb 2012
    • 401
    What Image are you using? Is it vix by any chance?
    • zooloo66
      • Feb 2010
      • 29
      Cheers
      you can get from here if on vix image [ViX_Misc] OE-Alliance OnDemand player official support and discussion thread.
      • sabbacool
        • Feb 2013
        • 48
        Yep vix, cheers
        • septicsmurf
          • Feb 2012
          • 401
          I had the same problem with feeds constantly being down, it was a vix error.
          Updated to vix 3.0 build 632 and the problem went away.
          • sabbacool
            • Feb 2013
            • 48
            Still didnt work, guess ill wait for the feeds to come back on, im on 632 now but ever time i go to the feeds it says its down for maintenance
            • septicsmurf
              • Feb 2012
              • 401
              The feeds aren't down as I've just been in the plugins.
              When that was happening to me another thing that worked was reflashing the image and doing a settings restore. Takes all of about 3 or 4 minutes but the feeds then worked again for a while.
              Either that or you can go to the world-of-satellite website and install ondemand manually.
              • RuberDuck
                • 1724
                The feeds are fine and have been for weeks, it was the forum it self that was taken down for vital maintenance.
                you can install OnDemand manaully via a telnet session but you will need one of the latest image Builds as the OnDemand plugin needs the new skin enhancments so any image over 600 should be fine..
                The telnet command is as follows.
                init 4 && opkg update && opkg install enigma2-plugin-extensions-ondemand && init 3
