In a bit of a kafuffle
  • dedemccaw
    • Dec 2012
    • 19
    Hi people was looking some help with a few thing if you's could help me out..
    Box is a vu duo clone v3 it has also been flashed with the 3.2 update
    Kernal - 3.1.1
    Drivers - 2012 - 10 - 25
    Version - vix 3.0
    Build - 521
    I seem to be getting a few problems though they do not happen to often, i installed the hard drive when i got the box but now the box does not see it at all... i'm i right in saying that i should have to go back to a stock image from vu to do a initalisation of the hdd? if so what image would that be and would it having the 3.2 update have a bearing on what stock image to use?
    The image is also a little buggy at times, there has been a few crashes and a few times it wouldn't switch on from stand by, my guess is this is from running the latest vix image even though i have the 3.2 update on it... what do yous think? could i put an old image on it again even though the 3.2 update has been put on it?
    And the last thing i can think of at the minute is, half of the music channels are not coming across right as the pictures are all fine though they all have the same audio on them, any one know why that would be?
    Thanks for your time people
  • DOUGALMCD
    • May 2011
    • 3229
    Press blue button>vix>mount manager you should see hdd info in here.
    In the music channels press audio on remote and select correct audio.
