Hi want a new vu+duo got dm800hd pro dont know the difference between vu+duo twin tuner or the solo i kmow the spec will be a lot difference on the solo but only want it to watch tv and be able to record a differenrt channel at the same time will i be wasting money if both do the same thing would appreciate any advice thank you mial
WHICH BOX
Solo has single tuner so unable to record and watch any channel while recording unless it's on the same transponder.
Duo does what you want but is becoming dated. Uno twin and Ultimo and Solo 2 are next step up in range.
Clone duo's are cheaper but can be troublesome. hth -
I bought a duo twin tuner a yr ago, happy with it, does its job. Only draw back is that the bloody thing gives an error msg from time to time. Likely down to all the plugins. There's a later version though. Fancy it myself. Look it up on world of satellite genuine thing.
Solo2 is the way to go. Only a bit more than the duo but with much more under the hood.
Can be had for around ?275 from Germany.Comment
