Tune failed only on certain channels
  • scottj130208
    • Apr 2011
    • 323
    My duo is giving tune failed on certain channels sky prem +1 does not work many more give tune failed this on on tuner A the signal level is at 83% strange it's certain channels tuner B no problems just tuner A playing up any one have any ideas thanks
  • cactikid
    • 12017
    loose sat cable?
    is the box a clone or original?
    • scottj130208
      • Apr 2011
      • 323
      Cables are tight and it's a clone
      • mezzyg
        • Apr 2010
        • 158
        Clone boxes have this problem, try rebooting the box to see if this works again
        Sent from my Nexus 4 using Tapatalk 2
        • Wingnut
          • 376
          mezzyg can you empty you pm inbox?, its full again, cheers
          • scottj130208
            • Apr 2011
            • 323
            Reboot doesn't change anything same problem must be faulty tuner it will work sometimes then will fluctuate signal then won't work again must be faulty
            • cactikid
              • 12017
              there was another duo clone tuner problem in the last week with a tuner with low signal now sorted,have a read in there
