My duo has only red light on front of LCD screen any ideas seen post showing replace a cap inside or maybe boot loader is corrupt maybe
Vu Duo Red Light Only
Tags: None
It's came out of red light light now stuck on starting tried a few v2 images but won't pick up usb I know these can be a pain with certain usb any way to flash via vu util without ethernet connectedComment
I'm having the exact same problem with my VU+ duo. It started with that it restarted itself after it had been on for a while and then it got stuck on "Starting...". When it had been turned off with the main switch at the back and then started again it got through the "Starting..." and the box worked again. This happened everyday for about one week, but now when I turn on the box only the red light is on but absolutely nothing happens. I have checked the power supply and it works and is giving the correct current on every pin in the socket, so that should not be the problem. One interesting thing is that the box reacts on the remote control. When I press a button the red light goes yellow,,,ish but nothing else happens.Comment
