My duo won't factory reset, I wanna start again but can't. Any ideas how to maybe force a factory reset. And why has this become an issue. Thanks in advance for replies chaps n chapettes
Factory reset?????
For reflashing the image plenty of guides around but best following the ones on here in the tutorial section and will have you up and running again in no time: http://www.digital-kaos.co.uk/forums...our-vu-203093/
Re: How to flash a VU+ Duo using a USB stickThe bootloader is in www.openvix.co.uk
The images are there too.
You flash the bootloader first and in the same way you would the image. Found this little ditty and it did the job. Sat box working normally again. thanks m8
A factory reset is quite misleading in that it does not return the unit back to factory condition, ie back to the original Vu image, it simply wipes the user area of the current image thats on the receiver and returns you back to the FIW ( first install wizard ) to set thngs up again.Comment
The .cfe file is a bootloader upgrade it has nothing to do with returning the box to a factory state, once you flash the bootloader you then have to flash a image to the receiver, flashing a new image first erases the flash then writes it anew with the image.Comment
