best steaming plugin
  • Mr G Monkey
    • 46
    Hi
    My channel 1 is not working and the other plugins are hit an miss. can anyone recommend a good english streaming plugin and where to get it and also how to install it
    thanks in the meantime
    This seems to be the most popular : http://www.digital-kaos.co.uk/forums...ml#post1973085
    • Mr G Monkey
      • 46
      Hi thanks, you dont know if there is step by step guides on how to install, have never done one before and dont want to brick my box. will it work ok on black hole175 verison i think.
      thanks again
        Download the OE1.6 version and ou will have a .ipk file transfer this via n FTP program to /tmp folder and then use the manual install of ipk file through the Blackhole menu system
        • Mr G Monkey
          • 46
          thanks for your help, did what you said, wont let me install. took a pic of what it said dont know if you can see, says collected errors, ERROR package dvbapp2 ....... file name that i downloaded from link. is not avaiable from any configured src.
          then failed to download dvbapp2........ perhaps you need to run 'opkg update' (should i do this and how do i update it)
          then cannat find package dvbapp2.... execution failed,
          any help would be great
          • reaper101
            • 80
            install this first
            blackhole ts panel - Downloads - Digital Kaos
            restart the box then open it via green button and update it restart the box open it again then goto addons and install tsmedia from the vuplus addons you can also do the opkg update thru this
            • Mr G Monkey
              • 46
              The ts panel is already on the box. Have tried installing tsmedia through it. Wont work through it either
              • reaper101
                • 80
                have you done the opkg update ( you may need to install a hard drive to do this update just use a usb stick and mount as media/hdd )
                • Mr G Monkey
                  • 46
                  Thanks for response havent done opkg update. Where do I get it at. Will it affect my box ie will I have to install channels set up timers etc again
                  • reaper101
                    • 80
                    just open tspanel goto addons - vuplus addons - tunisiasat plugins you will see opkg update bottom left press red button to install
