Unable to flash Vu+ Duo by USB
  • blackgator
    • Feb 2012
    • 17
    Just received a Vu+ Duo from china, v3.2.
    Have tried flashing a new image to it but won't work.
    I've extracted image and put it in root folder of usb memory stick in vuplus/duo folders.
    When I switch on box it doesn't flash. Tried a few images and 2 different usb devices. Same issue.
    Box is running latest Blackhole image at the minute.
    I have set up openbox m3 before and dm500s but really struggling with this one.
    Any advise would be great.
    (also having issue with configuring tuner. I select Single Tuner but it says "nothing connected" and I cannot select anything else)
    Have you tried all available USB ports on the receiver
    • blackgator
      • Feb 2012
      • 17
      Yeah, front port and 2 rear ports. No change.
      • cactikid
        • 12017
        try a few more formatted usb sticks,i even had issues with my original.
          Try Cactikid's suggestion as i have seen problems with some sticks and other sticks work no problem if that does not work you may have to flash it via the Serial port
          • blackgator
            • Feb 2012
            • 17
            Okay, I'll try another usb stick. Any u recommend?
            Don't have serial port on laptop, just usb to serial adapter and I heard they can cause issues.
            I,ll try another usb stick and let u know.
            • DOUGALMCD
              • May 2011
              • 3229
              When you highlight nothing connected does it not scroll left to right?
              It would be a good idea for you to do a full image back up by ftp or via usb as well before you start messing around with box.
              Most usb sticks work assuming you format them first your probably better with flashing usb as you can tell what it's doing rather than guess.
              • blackgator
                • Feb 2012
                • 17
                Got sandisk usb stick an flash worked.
                Can anyone suggest an image for me. Not sure which is best.
                Also, how to i check if I need to install the secret file thingy with the null modem cable and adapter. Back of box states v3.2.
                Big thanks so far guys. Appreciate it.
                  If its a Ferrari 3.2 version then in theory it should be able to handle any of the latest images available take your pick from Blackhole,Vix,OpenAAF,OpenPLI etc...
                  • gji25
                    • Feb 2010
                    • 353
                    Kingston flash or Toshiba flash sticks work ok for me. open pli image seems to be the best image ive tried on a original vu+ duo
                    dm500hd -dm500hd v2-vu+duo- triax 1.1m - inverto lnb - technomate 2300 motor- linksys ddwrt router
                    • tomhick024
                      • 559
                      Well Shxt anyway,
                      I have a similar problem but my Vu+DUO is stuck in some sort of loop, cannot flash with usb- tried loading the latest image first and then tried boot loader but box will not read usb. it goes straight to starting on display, then, VU+ duo appears. then displays the history channel.. no picture and pressing any button on the remote just brings up the info channel bar at bottom of screen.
                      I disconnected hard drive and made no diff. I can connect with DCC. is there any way to do full flash with DCC - afraid to go messing in case I really fxxk it up without checking in here first?
                      Tom
                      Whatever!!
                      • tomhick024
                        • 559
                        eventually it read the usb , didn't do anything diff to what I had tried,, maybe it over heated or something,, stumped!!
                        Whatever!!
