duo setting up
  • hayd0n
    • Jun 2011
    • 161
    duo setting up
    i have duo v.3 clone running vixopen i think is there away to make a back up so i can drop it on a frinds duo so save me some time his box clone v2 will this be ok and how do i do it thank
    Not too sure on Vix as i dont use it but i assume if its not in the menu there will be a plugin for it failing that use DCC to do the full backup
    • potrobber
      • Mar 2010
      • 493
      It would also depend on the image you have on your box if its a v3 image then no it wont run in a v2 box until you do the v3.2 upgrade on the v2 box if its a v2 image you have then it will be fine
      The v2 images are patched with older drivers you can do this simply enough to a v3 image with the ferrari addons manager if you need to
      • cactikid
        • 12017
        to be safer i would not advise it as original box will run ok on official image and drivers,if you transfer to his box knowing its a clone and it bricks it who replaces the box ?
        • RuberDuck
          • 1724
          ViX has it's own custom made image and backup managers built into the image by default, to access them press the blue button then ViX.
