new black hole
  • hayd0n
    • Jun 2011
    • 161
    new black hole
    just put the new black hole on my duo how do i get a cam and tsmedia plz help
  • benny/9
    • 1964
    for cams look in this thread for cams and how to load them
    Please Read Carefully!
    • hayd0n
      • Jun 2011
      • 161
      tryed mate put the etc and user in temp followed the step s saying upload a bh.tgz packaeg in the /temp directory before you can install addons
      • cactikid
        • 12017
        have you downloaded plugins from the internet i think there might be stuff there,there was with ts panel.
        • athenrybhoy
          • Jul 2012
          • 76
          create a new folder on desktop and name it bh cams ,unzip file containing cams and place them in it,conect to your duo with vucc/dcc ,on left side of screen look for bh cams in desktop click on it,on right side of screen double click tmp...back on left side right click and select upload on each of the cams ....go back to duo press green then yellow then press manual install bh packages ,should see your cams in there.....think i done this wrong first time ,sounds like what you are doing ,i was opening cams dont just drag and drop into the bh cams folder you create on desktop
          • hayd0n
            • Jun 2011
            • 161
            right dun that now how do i find the cam to activate and put my file in it
            • athenrybhoy
              • Jul 2012
              • 76
              press blue and scroll left or right to select
              • athenrybhoy
                • Jul 2012
                • 76
                file u need to edit is in ect... you know the one ...
                • hayd0n
                  • Jun 2011
                  • 161
                  wont let my select a cam
                  • athenrybhoy
                    • Jul 2012
                    • 76
                    what cam is selected when u press blue button
                    • athenrybhoy
                      • Jul 2012
                      • 76
                      does it tell u how many cam are installed?
                      • hayd0n
                        • Jun 2011
                        • 161
                        1 cam common interface
                        • athenrybhoy
                          • Jul 2012
                          • 76
                          ok cams are not installed ,did u manually get to manually install bh packages
                          • hayd0n
                            • Jun 2011
                            • 161
                            yep did that
                            • athenrybhoy
                              • Jul 2012
                              • 76
                              ok my fault forgot to say reboot box... then try blue button should say how many cams,just scroll left/ right to select cam
