I had to factory set my duo. But I am having a lot of diff mounting the internal hdd therefore pause rewind won't work . step by step help guys please . Thanks in advance for replies
I think i had it converting to ext/3 or 4. It is telling me that jobs are running in the background. Duo was doing the samething last night but was interupted,so starting again. When this is complete will this connect hdd to duo?
Blue button press vix > mount manager > ok > set up mounts > ok > Should say hard disk and size > scroll cursor to right till it says media /hdd > press green button to save. Should tell you updating mount locations and ask you to restart now. Now go try and record.
Followed your instructions, didn't work. I then went to time shift settings and tried to enable, but when i hit the green button i getting the following msg "The directory /hdd/timeshift/is not an EXT2,EXT3,EXT4 or NFS partition. Make sure you select a vailid partition type. "
It came installed when i bought it from w o s over a year ago. I had to remount it b4 wen the duo was giving me a lot of hassle and had to b reset. 500GB
Tells me to restart and when i do nothing has changed. I have no idea why the hdd disconnected in the first place. What is tspanel and how do i access it, is it a plugin? Think that maybe part of the solution if i am right.
I will post as much detail as i can later to-night or to - morrow.
The build number is 726
I copy and pasted this post. You may have to highlight it to read it. Sorry In mount manager i have the below information. (Size: unavailable Mount: none device: /dev/sda1 Type: unavailable.)
When i choose setup mount, i am then asked to save. Then when i restart a bar appears saying "tune failed"
I don't know if image manager has any relevance though it says the following.
(Device: there was a problem with this device, please reformat.)
I have disconnected other devices so as to get this sorted.
I am advised that all data will be lost , i hit the red button and assume nothing is happening. Then when i attempt to restart enigma i am advised that jobs are running in the back ground. Asside from that i was on another forum and was advised to reflash with build 724. But fearful that i will loose my channels cuz i already forgot how to reinstall them despite putting them in only 2 wks ago. Don't bother with tech stuff to much like hard work trying to hold a thought
