Duo2 images
  • manutd4life
    • 132
    Duo2 images
    Just got the duo2 and wondering which image will be the best to put on.
    i can only find the blackhole 2.0.0 OE2 and if i use blackhole, how do i add cccam,softcam etc ?
  • benny/9
    • 1964
    the info is on the forum mate,and once again just for you
    look at post 2 in this thread
    and the cams work on all blackhole and blackpole image versions
    Please Read Carefully!
    • septicsmurf
      • Feb 2012
      • 401
      Image is a very personal choice, try a few out, they only take a minute to flash.
      Vix is also a great image which can be found on the OpenViX website.
      • manutd4life
        • 132
        thanks for the info. i have a blackhole image i want to use but it is saying this, Warning: Duo2 requires a Cfe upgrade to V2 before you flash this image.
        now i have the file, i put it on my flash drive but the update screen doesnt appear, ive tried putting the image on without this but the same happens with the blackhole image, nothing. can anyone help?
        • benny/9
          • 1964
          if your box does'nt see the usb stick first format
          the stick to fat32 or try anouther stick vu models
          are a bit tetchy with usb sticks some work some dont.
          you flash the cfe the same way as the image
          when you take the file out of the rar or zip folder
          you should see a open folder --vuplus you send this
          folder to the stick do not open this folder any further,
          in side the vuplus folder is anouther open folder-- duo2
          and inside this folder is three files. just send the vuplus
          folder to the stick, turn the box off with switch on the rear
          put the stick in the front port and turn the box on again then
          follow the info and once it says finished take the stick out of
          the box and then reboot the box again by turning off and back
          on with the rear switch. then you need to clear the cfe off the stick
          and load a image on the stick to flash the image on the box, the same way
          • manutd4life
            • 132
            excellent, i had to use a usb stick with a micro sd card in it.
            is it normal for it to say checking usb for a few minutes?
            i reset the box and tried flashing again, all good now.
            thanks for your help
