Vu duo v 3 starting
  • scottj130208
    • Apr 2011
    • 323
    Vu duo v 3 starting
    Have a duo v3 it's a clone stuck on starting tried various USB which none are picked up by duo tried to update ic which works cfe by USB will not work seems like no power to USB tried external powered USB still the same tried vu util can't flash as need IP address really stuck any ideas or is j tag only option left scratching my head with this one
  • IAmATeaf
    • 591
    The front port on the clone Duo is pretty rubbish, if you've used it a lot to plug in USB drives then certainly on my box it can become unreliable so try slightly pushing the stick to the left and or right as the box boots to see if this helps. Remember be gentle
