Tuner Question
  • davecabezo
    Tuner Question
    Hi
    I have 4 dishes with twin LNB's on my roof controlled via 2 Diseq switches. On my Vu Duo I had the 2 Tuners set up with each tuner operating a diseq switch. I had a problem with rain getting into the connections due to storms we had here in Tenerife and I've had to swop gear on the roof to make 1 good system. ie 1 Diseq switch operated by tuner A.
    My question is:- If I set tuner B to loop to Tuner A will I be able to record different satellites at the same time
    Regards,
    Dave
  • alec
    • 345
    Originally posted by davecabezo
    Hi
    Regards,
    Dave
    You can only record or see the signal from that Satellite transponder you are on at that time.
