Vu+ Duo Tutorial
  • hoosty
    • Feb 2014
    • 16
    Vu+ Duo Tutorial
    can anyone tell me if there is a Vu+ Duo step by step tutorial available, thanks!
  • benny/9
    • 1964
    i'm guessing you mean how to flash the box
    how to flash a VU+ Duo receiver with a USB stick. required are just your favorite image and at least a 128mb memory stick formatted FAT32. when you download a image of your choice you open the zip or rar folder and extract a open folder named vuplus from it, do not open this folder, send it to your usb stick after you've Formatted the memory stick on your PC FAT32.then you Power off your VU+ Duo with the switch on the rear panel. Insert memory stick into front USB slot. turn the Power on your VU+ Duo and follow the box screen instructions,
    when it says finished, you remove the memory stick and turn the box off and after a few seconds turn back on and then on the tv screen you set up the menu etc. after this you can then add the extra's you need
    Please Read Carefully!
    • hoosty
      • Feb 2014
      • 16
      Hi Benny/9, i can flash my Vu+ Duo fine with BH 1.6.5, but if i try a more up to date version, is it 2.9 ?, it tells me to remove the stick and re-boot, and after doing this, it just stays on 'starting' and the red light stays on, like forever.
      also, is there any other software i need, like an EPG.
      can you advise me please ?
        Then that means your Vu Duo is more than likely a Clone receiver which is limited to certain versions of images it can use, if its a ferrari clone then have a look for a sticker that may say V2.0 or V3.2 on the back or underneath then have a look at this thread here: http://www.digital-kaos.co.uk/forums...s-only-256587/
        • hoosty
          • Feb 2014
          • 16
          Hi Digicon, i am pretty sure it's not a clone as i bought it from a reliable source at the going rate for the genuine article. also, it has worked ok since my mate flashed it for me a few months back, but last week it displayed a message that a file was either corrupt or missing, so i decided to re-flash it with the same vuplus image that my mate left on my pc.
          • benny/9
            • 1964
            i read elsewhere that someone had a image from another team on his vu and when he tried to update to the latest bh 209 he had the same problem as you, he was told to flash a earlier bh image first then flash the latest bh 209 image, he first flashed
            the bh 207 on his box and that loaded ok so he then flashed the 209 image and that loaded and his box is working first class if you want to use the latest image, try the same way and see if that clears the problem.
            • mdt
              • 3034
              you could try flashing the official stock VU DUO image direct from VU to put the stb back to its factory state then try a 3rd party image using the same OE 1.6 or OE 2.0,regards mdt
              • hoosty
                • Feb 2014
                • 16
                thanks everyone for your help, i think i have it sorted out. just one other minor problem now, when i was removing all the N/A programs from my bouquets, i inadvertently pressed the activate picture in picture instead of remove and i can't figure out how to deactivate it, can you advise? thank you.
                  use the same button to deactivate it.
                  • hoosty
                    • Feb 2014
                    • 16
                    thanks digicon, but tried that and it is still there.
                    • hoosty
                      • Feb 2014
                      • 16
                      after all that trouble setting up, i now have a message onscreen say 'Deflating XEPGDB', WHAT'S THAT ABOUT?
                        Thats CrossEPG downloading and converting over the EPG data for you
                        • hoosty
                          • Feb 2014
                          • 16
                          yeah, it's just finished, thanks again.
                          • hoosty
                            • Feb 2014
                            • 16
                            Hi, i have the crossepg thing running again and it takes ages and in the meantime, i cannot change channels, how long should it take and is there a way to schedule it to run during the night ?
                            thanks all.
                              thanks all.
                              No you cant change channel and yes there is a schedule download option in the Crossepg menu which can be found in the settings menu
