BISS line on a vuduo?
  • pappamontanna
    • Mar 2012
    • 30
    please i need help how do I put a Biss line on a VU duo?
  • mdt
    • 3034
    example from softcam.key file using MG**** emulator which is in USR/KEYS. open the file using notepad++ and edit to suite the channel you wish to watch(if key is public)
    F 00041FFF 00 11XXXXXXXXXXXX00 ;ENTV (22.0?W)
    F 00041FFF 01 11XXXXXXXXXXXX00 ;ENTV (22.0?W)
    after a couple of hours of searching/reading on the WWW you should have your box running without problems but watch for the sid clash ect but this can be worked around by using different emulators.regards mdt
    • pappamontanna
      • Mar 2012
      • 30
      tried the above didn't work for me, on my VU DUO I have on tuner 1 28.2e with MGxxxxxxxx which works fine
      tuner 2 is on 27.5w on a different dish,do I put biss line on the same MGxxxx? if not how do I put a soft cam on?
      I am stuck and need a step by step guide please.
      • mdt
        • 3034
        you will need to run OS***Ymod and openpli image as a non-standard system is in use on 27.5west,regards mdt
