ts media
  • jimbofz
    • Mar 2010
    • 65
    ts media
    is it possible to get ts media installed and working on v2 duo clone?
    im using vix apollo 019
  • DOUGALMCD
    • May 2011
    • 3229
    Yes mate works no problem.
    • jimbofz
      • Mar 2010
      • 65
      how do i load it please,do i use usb stick or is it done via addon manager (cant see it in addon manager list)
      • benny/9
        • 1964
        this way
        use the E2 v1.50 dcc panel and load the tspanel/tsmedia or any pluggin this way
        you load the tspanel/tsmedia etc; after the image of your choice is flashed
        open the dcc and click [TOOLS] then [packages]
        in the green section on the left of the panel
        a list of the packages on your box will upload
        under the list are two bar strips [update package list]
        and [upload package] click upload package bar a window will
        open find and click on th tspanel file then click open on the
        window the file will now load on your package list and will give
        the loading info in the protocol pane under the package list.
        once loaded,close the dcc and re start your box when it
        re boots you will find the tspanel in your menu list ready to use
        just remember to use the correct section and the items for the image
        you have on the box this method also works with all linux box models
        Please Read Carefully!
        • jimbofz
          • Mar 2010
          • 65
          thanks for reply i have dcc v2.96
          and when i connect and go to upload package i only have bootmanager or startmenu.
          when i click update packages i get ipkg-cl not found.
          as you advised do i have to use specifically dcc v 150?
          ive looked in the downloads section and can only find v 1.30
          • benny/9
            • 1964
            you can find it here it's a free download
            BernyR's Dreambox Tools
            • jimbofz
              • Mar 2010
              • 65
              have followed your instructions ,now have dcc v1.50 connected via router clicked update packages,all i get is folder lang?
              so unticked opkg and ticked ipkg tried again then protocol box starts to fill with updated lists of avail packages when it finished
              a get index path not found ok i also get yellow bar loading packages any ideas where im going wrong please
              also in the tools menu the root memory is 95% full is this normal?
              • benny/9
                • 1964
                if you have taken the tsmedia file from it's folder and put it on your desktop
                when you click the upload package bar on the dcc it should take you to a window
                on your computer where you click browse and find the tsmedia file then click open
                and the window will close and you will see the file upload un the dcc panel once finished
                you close the dcc panel and go to the box and turn it off and on with switch on the rear
                panel and once it boots the file will be loaded and you should see it in the menu list
                • jimbofz
                  • Mar 2010
                  • 65
                  thanks for your patience ive tried everything above:
                  installed extracted tsmedia from desktop and ftp into tmp then rebooted ,and still cant get it installed ,so out of interest i tried to install mgcam 1.38 from boxs addon manager, just to see if box would accept any addon, and rebooted,
                  and i get the following :collected errors no space left on device pkg write filelist failed to open.var/lib/opkg/info e2 plugin ext tsmedia no space left on device?
                  when in dcc tools menu memory info shows root almost full at 96%,is this why ts media install fails?
                  also in dcc tools/ packages i get index path not found with a yellow bar "loading packages" but nothing loads into the packet list.
                  reflashed full image and tried again ,now memory info shows root at 55%
                  • jimbofz
                    • Mar 2010
                    • 65
                    hi benny9,when i look in dcc/usr/lib/enigma2/python/plugins/extensions /tspanel/_init_.pyo
                    its size is 164 attributes 625
                    so its in the box when i go to box addon menu and click green for downloads ,please wait
                    after ages
                    i exit and get the message
                    some plugins not avail extensions/tspanel(bad magic number in/usr/lib/enigma2/python/plugins/extensions/tspanel/_init_.pyo
                    could it be that the "bad magic number" refers to attributes 625?
                      Just to let you know it is well documented that both TSpanel and TSmedia have problems with the OpenVix image, You may have better Luck trying a different image
                      • portbhoy
                        • 717
                        Also TS media is in Vix feeds and can be downloaded via pluggins.
                        • jimbofz
                          • Mar 2010
                          • 65
                          when i try to dload via plugins,i get:
                          some plugins not avail ext /tspanel(bad magic number in /usr
                          im curious if anybody has been able to use this tsmedia with vix?
                          ive no problem trying another image that it works with
                          ( as long as cccam is still possible)
                          any suggestions as to the best one please
                          ive previously used open pli4 but epg was a headache with this image and vix epg is vgood
                          • DOUGALMCD
                            • May 2011
                            • 3229
                            In the vix image you download tsmedia from plugins as stated above i'm sure at the moment it's 7.2 full download it from plugins restart it update ts media in tools to 7.5 although 7.6 may be available soon. Ts media works fine on vix You will probably find it's Ts panel causing you headache. You can download other stuff from plugins on vix too. It looks like you will have to do a reflash anyway.
                            • piopat
                              • 708
                              you mention your vu is a clone , and I see you have been advised to perhaps try vix image , I have to warn you to use care when using vix images as the more recent images have clone killing software in them .
