I want to remove old config files and the data (if there any) from my duo. Can i do this via DCC if so what do i look for and what process do i follow. Thanks in advance guys
old config file removal
yes open dcc then clip ftp next double left click the etc folder
and scroll down the list to the cfg file and if you wish to remove the file right click on it
and select delete from the list that opens, or you can right click on the cfg file
and select edit to open it and then go to what you want to remove, highlight it
and at the top left click on the scissors to remove then left click the save button
at the top left and a small panel will ask are you sure and click yes job done
just remember if your going to replace this file when you send the new cfg file to the
box it over writes and removes the one already in the boxLast edited by benny/9; 30 July, 2014, 17:58.Please Read Carefully!
,glad ya sorted,iffy subject with rules etc.
