im in need of help trying to put enigma2-plugin-ccam on my vu+duo but a error /bin/sh:syntax error unexpected
HELP
hi we have to be careful here with forum rules , so i wont mention anything about cs and ill just briefly talk about plugins . did you try to install this plugin other times ? or did you try to install other versions of the same plugin multiple times ? . what im saying is that you may have multiple versions installed and as such they could then very simply put be clashing with each other , as they wont know which version is meant to be used . if you have multiple versions of the same plugin or multiple versions of other similar plugins installed uninstall all the cam plugins except one and see if that cures the problem .i love it when a dreambox comes together.
