VU DUO PROBS.
  • beatboxbob
    • Aug 2013
    • 22
    VU DUO PROBS.
    Ok I have a duo and a mini solo for emergencies. Now the duo is booting to the blackhole blue screen and says starting gui. But no picture appears on any channel fta included.i have full functionality of the menu . The image is bh 2.1.0 build 2014-05-07-master. If I then unplug the duo and plug in the solo I have channels perfectly. Duo has been given to me so I don?t know it?s history. Everything seems to function ie menu wise just no pic. Maybe set up incorrectly? I have a motorised set up with 2 core from sat dish.any help be appreciated it.
  • cactikid
    • 12017
    is duo connected to lan and you have run network test ? do you need to reboot box and router.might also check if the *** needs restarting and other thing is green.forum rules apply from there m8.
    if it is you cannot get a display from the duo can you try a scart lead and go through the settings with the wizard to see if that works,could box be a clone and hdmi port faulty.dont plug/unplug hdmi while both units on as that can do damage.
    • beatboxbob
      • Aug 2013
      • 22
      will check all you have suggested when i get home later. thank you for your suggestions and yes it is indeed a clone.
      • beatboxbob
        • Aug 2013
        • 22
        Just seen on video input selection when image flashed there is no hdmi option although i have a hdmi port, why is this... obviously this must be the prob of no display because thats how it was linked to the tv. options are ..... dvi ... scart ,.... YPbPr. i do not have a scart socket on my tv so what are my options please. why would there be no hdmi selection for input but there is a hdmi port on duo?
        • cactikid
          • 12017
          think the experts need to answer that but wonder if an image from dreambox that has no hdmi output used?
          • beatboxbob
            • Aug 2013
            • 22
            maybe a newer image might help.
            • cactikid
              • 12017
              your box is a clone so cannot use genuine image,hence hopefully some expert might know.
              • beatboxbob
                • Aug 2013
                • 22
                yeah sorted that issue with hades openvix image, now i can select hdmi but having problems getting channels to show on screen even though i have several sats installed , tune failed or timeout for tuner lock messages. also if i do an autoscan of 28.2 it finds nothing.
                • cactikid
                  • 12017
                  you did not sort out your problem but may kill box.you cannot use genuine images on clones as its a timebomb waiting to brick your box.
                  • beatboxbob
                    • Aug 2013
                    • 22
                    i was told image was for clone vu duo. any other images suitable ?
                    • cactikid
                      • 12017
                      thought someone might have answered you,i dont use clones so cannot say.
                      maybe best to open new post saying
                      clone vu duo image needed?
                      you need to be 100% sure its safe and its a patched version for that box. and mention if any stickers underneath like v?? or v??
                      • beatboxbob
                        • Aug 2013
                        • 22
                        prolly end up binning it... doing my head in now. cant understand the original problem though.
                          Image would depend on what version security chip is installed on the clone duo these range from 2.0,2.1,3.0 so you have to choose the correct image for the ferrari security chip, It should say somewhere on the receiver what version it is
                          • beatboxbob
                            • Aug 2013
                            • 22
                            yeah sticker says 2.3. but problem is i cannot pick up any channels , tried 2 sat dishes same problem 0 channels found on scan. tuner configured to simple single 28.2 with tuner b not config. then tried on static dish, same result no channels found. plug in my spare enigma 2 reciever and viola everything is as should be.
                            • shaunfree
                              • 358
                              pm sent bob cheers shaun
