Can anyone help??
  • wurz
    • Apr 2010
    • 123
    Can anyone help??
    Hi,
    I've got a problem with a Duo clone that I can't get sorted.
    I accidentally ran a pen with a "magibox" bootloader that I use for Cloud4 boxes.
    Now the duo will not accept a standard flash via usb because it is looking for a "magibox" file system on the pen. I have tried magibox images but when flashing the process never finishes and box wont boot afterwards stays on "starting". Obviously the magibox image is incompatible with Duos.
    I need this box to accept a standard duo image but because it is now set up to take incompatible magibox images the box is bricked.
    Is there a way to convert a standard Duo bootloader to Magibox format, flash this to the box, then the box should take the standard Duo images again.
    Or is there another solution?
    I hope that's a clear description of my issue. Any help will be greatly appreciated.
  • cactikid
    • 12017
    as been a clone you have to use correct images for that box.you would need the bootloader by the clone maker then the image.how many different clone manufacturers have done this model?
