Can Only Get FTA On VU Solo
This topic is closed.
  • intel
    • Apr 2010
    • 128
    I just brought a VU+ Solo and I can only get the FTA channels to work, I have FTP across to the box:
    enigma2-plugin-cams-cccam.2.0.11_1.0_mipsel.ipk
    CCcam.cfg
    Installed the plugin and made the CCcam active, but I made my own cfg file and this is where I think the problem lies: I edited it to read:
    c: server port user pass
    I placed it into the /etc/ folder
    and the name of the file is: CCcam.cfg
    but still only getting the FTA channels (the sat feed is good as well as the Cline and the internet as If I plug in a BM7000s all works ok)
    Any idea what I am going wrong please?
  • manster
    • Sep 2009
    • 229
    not sure if you can talk about this on here espdecially the sea lions ???
    what image are you using ? usually u just load ur image scan for channels and add your sea lion ? dont think u need to alter ccam apart from in your image almost automatically
    • intel
      • Apr 2010
      • 128
      Sorry I got it from a supplier and he said all that was required was to add the sea lion info.
      How to work the box is a little new to me as I had a Blade before this, where can you tell what image had been loaded into the box please?
      I also done a network test and that passed so I guess it connecting to the internet ok,
      • manster
        • Sep 2009
        • 229
        it will probably be either VIX or Blackhole image. plenty info on here spend a couple of hours reading.
        • intel
          • Apr 2010
          • 128
          Sorry m8, I should have added that it did say VIX when loading.
          • mdt
            • 3034
            have you activated c**am 2.1.1 in the softcam menu? regards mdt
            • intel
              • Apr 2010
              • 128
              Yes m8 that's active can I double check the cfg file with you please...........I just have the one line in there that reads
              Notice the space after c: and then also the space after the server name etc....is this how it should read?
              • Bann32
                • Oct 2011
                • 518
                in your ftp program, right click the file and check the permissions.
                • intel
                  • Apr 2010
                  • 128
                  Permissions are set to read / write I did change the c: to a Capital C: but that made no difference - not even sure if that is where the problems lies?
                  • intel
                    • Apr 2010
                    • 128
                    I just noticed in CCcam nfo - there is a red dot next to the name of my server should this be green? I done another network test and that seems to be ok, plus I can ftp to the box across my network.
                    Also on my blade the server was set up under Newcamd with the same server details, but I cant find a Newcamd under any of the downloads.
                    • jamesyboyz88
                      • Nov 2012
                      • 17
                      CCcam.cfg
                      Where can i find this plug in ?
                      Thanks in advance
                      • digicon
                        • 8261
                        CCcam.cfg
                        Thanks in advance
                        Not on here sorry perhaps upload TSpanel to your box and get hold of the Cams from there.
