Vix EPG causing system crash
  • murphyb007
    • Aug 2012
    • 88
    have installed the new VIX 3.0 Image on my Vu Duo ? Looks Great and very practical. My only Gripe is when I go into the Settings > Cross EPG > and try to go down to open TV the system crashes, restart it and go in again ? Same thing. Can anyone make any recommendation as to how to get around this? The EPG Panel is coming up but nothing on it,
  • RuberDuck
    • 1724
    please submit any and all crash logs pertaining to these incidents either directly to us via the inbuilt logs manager in the image or if possible upload them to our forum.
    Although i cant say that i have had any such problems with any of my 5 receivers all of which use the latest ViX 3.0 images and CrossEPG / OpenTV.
    • dell_xps
      • 2558
      Where do you have it saving to ? if internal flash change it to hard drive !!
      • murphyb007
        • Aug 2012
        • 88
        Hi, I have them saving to the installed hard drive, crashes everytime I go into the same settings,
        • DOUGALMCD
          • May 2011
          • 3229
          Hi there it looks and sounds like you have'nt set it up properly so I would check the hard drive is mounted and path set up as well as epg path. If these are ok you would be better reflashing from start as the image may be corrupted. hth
          • murphyb007
            • Aug 2012
            • 88
            Looking like its the corrupt theory, everything is mounted and pathed etc...
            • irorwayrix
              • Jun 2017
              • 14
              hi there im only seem to be getting epg for free view channel and not anything else. Any one got any solutions for this ive tried deleteing the epg and un installing cross epg downloader and re installing everything but still getting same fault...... any help be apprecated
              • nbtechnic
                • Jan 2016
                • 321
                Did you solve the problem or not?
