hallo,
i wil see first wat the skin emage!!!
HD Glass 16 skins by shamann
Re: fix
Hi,Hi all
Is there anyone that can help with this problem?
as i said in post 70 i am using hd glass 16 v 3.68
downloaded from tunisiasat the skin is excellent except when you press blue to go to the blue panel i.e. addons it crashes to the green screen, it happens on all versions of HDG 16 but not 15
i have checked the crash log but can't find the problem.
any help would be appreciated as this is by far the best skin out there........
my set up is
Original Dm800HD edg nemasis 2.1 in flash.
usb and hdd installed
Could you let me know how you managed to fix this?
ThanksLeave a comment:
HD Glass16 ver. 3.91
- fix support for plugin EMC 3.0.0
- fix detection of Nemesis image 101r1( do not use this and next versions in older version of Nemesis)
- fix icon type 1
- icons in download updated
Update is available online via setupAttached FilesLeave a comment:
HD Glass16 ver. 3.79
- added selecet picon_default, next, marker... black/white
- added enable/disable OLED off in standby
- help updated
- code optimalisation - acceleration
Update is also available online via setupAttached FilesLeave a comment:
HD Glass16 ver. 3.76
- added support for DE 2.1 (older removed)
- updated encoding.conf
- changed default value of fade in setup to disable
HD Glass16 ver. 3.75
- added support for Nemesis 2.4 (older removed)
HD Glass 16
Hi all
my set up is
usb and hdd installedLeave a comment:
HD Glass16 ver. 3.66
- added new download menu in setup
- used 1 path to all types picon-s, help and sets of icon, ipk has a size of 2.7MB
- optimized code, better use of ram
- picons are available in white and black
ipk not contains piconProv, piconSat, piconCam and set of icons / previews, after update can be downloaded via the to download menu: all of picons, help and icons, ipk contains a
default set of icons - 1, before the download must set the path, that is used for all Picon, help and icons, definitions piconPaths.conf are no longer used, the file is removed from the ipk
update is available online through the skin setupLeave a comment:
Hi Guys
HD Glass 16 v 3.68 with edg nemasis 2.1 on DM800HD
Crashing on blue button press. Useing none button menu.
Any fix?Leave a comment:
Leave a comment:
HD Glass16 ver. 3.49
- added new option: "update chceck" in setup - press button 7 - here you can check available updated online versions of the skin, if updated version is available can be installed immediately (autodection mips/sh4 and autodetection ipkg/opkg)
- small update piconProv (thx ftryskac)Attached FilesLeave a comment:
Leave a comment:
