how do i make a FULL back up on vu duo
  • grogking
    • Jul 2010
    • 69
    hi
    im worried that if somthing goes wrong i will loose all my hard work like skins , channels , lines etc.......so can i make a full back up to usb stick i just put the stick back in and reflash it and i will be back as i was?
    cheers
    depends on what image you have on the box some provide a fullbackup or personalised option in the main menu and some you will have to download a plugin to backup your box
    • grogking
      • Jul 2010
      • 69
      hi digicon
      im using blackhole 2.0.3 and i have found the back up menu
      now do i do a personal back up or full back up?
      cheers
        A personal backup will allow you to save Channel lists, Cams, Cron Jobs etc... so that you can transfer into another blackhole image.
        The Full backup does all of the above and also the image itself so if your box becomes corrupt you just flash the full backup or if your trying a different image you always have a backup if you dont like the other image.
        Personally i do both a personal and a full backup this way your covered for any eventuality.
        • cactikid
          • 12017
          wonder if he has internal hdd and save it there instead?
          • grogking
            • Jul 2010
            • 69
            hi cactikid....that was actually my next question!!
            yes i do have an internal hdd and was going to say do i save it on to there as what if my hard drive fails.....but i tried to change it to usb but it wouldnt change BUT i didnt have usb plugged in.....if i plug usb stick in should i save to that .....is that better?
            • cactikid
              • 12017
              might get overcrowded on usb if your storing a backup image on it,best to use picons and epg to stick only,if hard drive fails it fails.
              • grogking
                • Jul 2010
                • 69
                I just thought a 1gb usb stick would have been safer as its seperate from the box?
                  Its always advisable when you have made a backup to store in 2 different places maybe one on the receivers Hard Drive or USB and one on your main PC/laptop
