Softcams
  • P&D
    • 2684
    Softcams
    Is it possible to put a softcam on a VU+ solo 2 ??
    Latest Vix image
    Many thx
  • benny/9
    • 1964
    they can be added on all images
    via the tmp folder then you load
    them from the manual package install
    section in the box menu, here are the cam
    packs for you
    Last edited by digicon; 1 October, 2013, 23:28. Reason: Removed Cam Pack and replaced with External link
    Please Read Carefully!
      Hi Benny,
      Sorry my good man but we cant hold any form of cams on the site including built into images due to the rules, We can though link to them externally from other hosting sites without a problem so i have edited your post to reflect this.
      Thank you
      • P&D
        • 2684
        Hi many thx benny/9 for the reply....
        Sorry my 1st post is misleading (sorry about this) i already have some of them installed on the VU....ccam 2.4.1 & mgccam also oscam
        the box is running great many thx for the help off other members of the forum...
        I mean the k**s like the ones in the Latest Technomate Softcam Keys *Regularly Updated*
        or similar to work with the VU
        Not sure if this is possible (i could do it on the F3 box i had) but is it possible on this box.....
        or am i barking you the wrong tree ???
        Only had the box under a week....as digicon assured me that the setup it easy (which it was) & a lot of reading helped thx again for the pointers mate
        Had a play with the B/H latest image...it's ok... but now i find the openvix is more user friendly & easier to get your head round...
        I have found out how to load stuff on the box via ftp & ipk & usb....editing files that i need to....
        After all the the above said.......i have the files for the F3 box that opened some sat's that i could watch. lets say 39.2E ...N**a S***t... is it possible to put the same file's on the VU
        attached below...
        Or again am i barking up the wrong tree...to get what i want
        Just cannot get my head around where to put them ...&..which flies go where .....iv'e try'd them in Var/keys..also Usr/keys
        Any pointer's plz anyone thx in advance...
          Ok
          Here we go not tested by myself but here is the latest Dreambox softcam.key file which goes into /usr/keys:
          Update: Bulsat 39.0?E Irdeto Active and Next key's
          Cablecom, Swiss Cable
          SRTV Feed 16?E BISS
          NBA Pool Europe 10?E BISS
          Rai october 13.0?E
          Rai 13.0?E September
          NBA TV HD 10.0?E BISS
          Barca tv (feed) 10.0?E BISS
          MUTV 10.0?E Biss
          USRSC Europe ESPN 10?E BISS
          ETV 3.1?E BISS
          EVN TV BISS 7?E
          Sinema TV Aksiyon HD & Sinema Ask TV HD 4.9?E BISS
          NLO TV 4.8?E BISS
          Pershy Natsionaly 4.0?W BISS
          REN TV 49.0?E BISS
          Art Prime Sport 49?E BISS
          BBC Package 27.5?W BISS
          Fox Crime Africa SD 12.5W BISS
          ESPN Caribbean & ESPN Syndication 15?W BISS
          Eurofootball Gonki 9.0?E BISS
          TNTsat Viaccess 19.2?E
          CS SkyLink 23.5?E CryptoWorks
          DigiTurk 7?E CryptoWorks
          Upc Direct 0.8?W CryptoWorks
          ORF & AustriaSat 19.2?E CryptoWorks
          UPC Cablecom (Swiss cable network) NagraVision
          Thanks to Serjoga for all the hard work, just to let you know you will need 2 cam emulator's for this key file to work one begins with C and the other begins with M and ends 1.38.
          Just to let you know why you need the 2 some are read by one emulator and some by the other.
          • P&D
            • 2684
            Hi digicon many thx for the answer
            i will try them later when i finish at work.....
            When you say i need the 2 files ...i now have them....do you just swap & activate them from the menu...i know they will not both run at the same time...
            what i'm asking is one file will work with some sat's (lets say the M file) .....if the sat does not clear then swap to the other file (C) ??
            Sorry to be a pain mate...so the dreambox k**s are ok for the E2 systems....
            Regards P&D
              Dreambox are Enigma2 so yes they work on any E2 Linux receiver.
              And again correct for some channels that wont open on one cam with the keys you swap to the other cam, as you are now using the Vix image i am unfamiliar if it has an Autocam function built in.
              Blackhole does have Autocam function built in so when you get channels open with say Cam A you save these to open with A and the rest you save with Cam B. So when you go to that said channel it opens with either A or B automatically.
              Like i said i have no idea if the Vix image has this function so you may have to have a look around the menu system
              • P&D
                • 2684
                Hi digicon many thx for the pointers
                I have re-installed B/H 2.0.6 with both the files you have mentioned above...all working great mate only had time to check 39E & N*** S***** opens
                so i will check he others later also thx for the pointers with the autocam....great little thing save swapping it everytime you change the sat ...
                My next challenge is find sats i can open......1. last question mate should the sats above that have the Bliss keys open with the same file ???
                Regards P&D
                  They should yes again though it will depend if the key in the file is current or not even though they list them up to date even the softcam makers have been known to leave old and dead keys in the file, try a few and see how you go as some may have a clash with others due to format
                  • P&D
                    • 2684
                    Many thx for all your help digicon....
                    You are defo on my Christmas card list
                    Only for your advice i wouldn't of took the next step into the wounderful world of the Sat's
                    As you said to me in one of your post's it's not the daunting to setup & take the next setp (glad i listened to you).....
                    My advice to anyone & all
                    If your thing of upgrading from the CHEAP boxes go for it....motor dish setup 3 days (Don't laugh) 1st attempted
                    Box setup 3 days after trying the Vix image & the B/hole image (& many pointers from forum members) Many thx to all.....
                    I now can pass on what i have learnt this week to other members starting out....
                    Again many thx Phil
                    • DigitalVandal
                      • Jan 2014
                      • 138
                      Thought i'd bring this thread back rather than starting a new one. Not sure where to put the key files on my VU+Duo2. Any pointers? cheers.
                      • mdt
                        • 3034
                        USR/KEYS,regards mdt
                        • DigitalVandal
                          • Jan 2014
                          • 138
                          top man. thanks for almost immediate answer.
                            And while we are on it might as well try and keep them up to date:
                            Thanks to Serjoga for the key File
                            ADD: ESP2 NE Russian 13.0?E 11240 V 27500 CCW's
                            NTV Mir 4.0?W BISS
                            Juventus TV Channel ("ITA 392") 5?W BISS
                            BBC Package 27.5?W BISS DOWN
                            NLO TV 4.9?E BISS
                            Chveni Magti, Magti Kino, Comedy Arkhi, Magti Hiti HD 4.9?E BISS
                            Italy Service & Italy Service 2 & Italy Service 3 & Italiy Service 4 9?E BISS
                            FOX Sports 9?E BISS
                            BARCA FeeD 10.0?E BISS
                            NBA Pool Europe 10?E BISS DOWN
                            STS International 13.0?E BISS
                            K**** D1 16.0?E BISS
                            SRTV Feed 16?E BISS
                            Topaz 1 21.5E BISS
                            CaspioNet and CaspioNet_test 31.5?E BISS
                            BTB 31.5?E BISS
                            Comedy Central 31.5?E BISS
                            Region TV 46?E BISS
                            CTC Love 85.1?E BISS
                            Mir Belogorje 85.1?E BISS "radio"
                            TNT Sat (France) HD 19.2E Viaccess Only with o****-ymodv18-t50
                            TNT Sat (France) SD 19.2E Viaccess Only with o****-ymodv18-t50
                            Ant-1 Europe 9?E Viaccess
                            GMM Package 78.5?E Irdeto
                            • DigitalVandal
                              • Jan 2014
                              • 138
                              Do they work with 1.35 as they're not opening for me.
