Dummies guide for setting up your VU+
  • aftermath
    • 4345
    I borrowed this off my mate Data 100 from another forum..
    1. Install image.
    Download a USB image file, eg Dream Elite from
    Unzip the vuplus folder to the root directory of a USB Pen Drive.
    Power off Vu+ with switch on the back
    Insert USB Pen Drive into the USB socket on Vu+
    Power on Vu+
    Image will auto install from the USB Stick.
    Look at the display on the receiver, it'll display when the update has finished.
    Remove the USB Stick
    Power off receiver.
    Power on Receiver.
    Image is now installed.
    2. Network
    Connect an Ethernet LAN cable from your router to your Vu+ Ethernet port.
    Press Menu
    Select Set Up
    Select System
    Select Network
    Select Network w i z a r d and press OK.
    3. Setup Motorised Dish using USALS
    First get your longitude & latitude info from multimap.com
    Enter your post code into multimap.com and you'll get the correct LON & LAT info for your location.
    Example if I enter the following UK postal code: SE1 6JZ
    I get the following LON & LAT:
    LON: 0.104 WEST
    LAT: 51.497 NORTH
    Press Menu
    Select Setup
    Select Service searching
    Select Tuner configuration
    Select Tuner A and press OK
    Configuration Mode: Simple
    Mode: Positioner
    Longitude: input the info from multimap
    Latitude: input the info from multimap
    Press OK to save.
    Press Menu
    Select Setup
    Select service searching
    Select Positioner Setup
    Select goto 0 Press RED Button
    Dish should now goto 1w.
    4. Download Channel List
    Press Green Button
    Press Yellow Button (Addons)
    Select Addon Download Manager
    Select Enigma2 Settings
    Select Likra E2 Setting Motor and press OK.
    5. Install cam
    Press Green Button
    Select Addons Download Manager Press OK
    Select Image Cams Press OK
    Select the cam you want to install and press OK
    6. Activate cam
    Press Blue button.
    Use Left & Right Keys to select an installed cam and press OK.
    This is enough to get you started, the fun starts learning the rest.
    These instructions are for Dream Elite Image other images Green & Yellow buttons might be configured slightly different
  • drahcirk03
    • May 2011
    • 13
    wen i press yellow button ,i get a green message saying ,its encountered a problem and has to close, any ideas please,
    • RuberDuck
      • 1724
      we need more details such as what image are you using and exactly what you did up to the crash. also a copy of your crash log from the box would be helpful, this can be found in HDD on your receiver.
      • drahcirk03
        • May 2011
        • 13
        ull have to forgive me as this is totally new to me, however, the message loading enigma 2 ,stays on screen and ,doesnt finish is that right?, am using vix image,
        • dell_xps
          • 2558
          It should go off then you should get a pic of whatever channel you are on.
          have you scanned channels ?
          • drahcirk03
            • May 2011
            • 13
            yes ,h/bird and 28.2 ,can see all the fta channs, it just says loading enigma,
            • dell_xps
              • 2558
              Are you using your own sly card or else ?
              • drahcirk03
                • May 2011
                • 13
                hav tried to sort out by reading but cant get any further, it still says loading enigms 11 ,and no im not using a sky card,
                • cyrill22
                  • Apr 2009
                  bootloader
                  hi new to vu + solo do i load the bootloader before image ? and where do i find the boot loader? .
                  Regards cyrill22
                  • potrobber
                    • Mar 2010
                    • 493
                    hi cyrill
                    what image is on your solo and is it genuine or clone?
                    • baker_boy
                      • Apr 2010
                      I'm looking to buy one of these systems are they gd and easy to step up?
