vu zero gui stretch
  • shaunfree
    • 358
    vu zero gui stretch
    hi all having probs with gui screen with BH image(small gui) ie when i open autobouquets it is small my gui seems to be in middle and not stretched across screen cheers shaun
  • DOUGALMCD
    • May 2011
    • 3229
    Not on bh at the moment but should be sorted out in settings.
    • shaunfree
      • 358
      thanks doug how would i sort with settings cheers shaun
      • DOUGALMCD
        • May 2011
        • 3229
        As I said not on bh at moment using vix and menu-system-settings-user interface-position set up. So should be something similar in bh. hth
        • shaunfree
          • 358
          thanks again doug tried ui position plugin but makes no differance to the gui screen cheers shaun
          • DOUGALMCD
            • May 2011
            • 3229
            Have you tried other images to check? Picture screen is okay I assume it's just interface.
            • shaunfree
              • 358
              hi doug yes picture ok just interface what is small,when i open autobouquets and try to set up 4 region i cannot see what iam selecting cheers shaun
              • DOUGALMCD
                • May 2011
                • 3229
                BH image press green button now in green panel scroll down to and select UI position setup select left/width/top/height whichever one you want to adjust Then use D pad on remote to srtetch or minimise interface. Then save it press green button. hth
                • shaunfree
                  • 358
                  thanks doug tried that but gui is in middle and cant seem to stretch it to full screen as it goes just left or right cheers shaun
