to use these drivers open the relevant archive using winrar
now navigate to
on your box
backup the files in this folder first then overwrite them with the ones that you download, there should be four files in total.
once the files have been transferred exit out of the FTP program and start a telnet session ( DO NOT REBOOT THE RECEIVER YET. ) once you have logged in issue the following command
after issuing the mentioned command you can now reboot the receiver. also please note these are beta drivers and as such you should always backup your existing drivers in case things go wrong and you need to go back to them. as always if your unsure about any part of this leave well alone.
20110929
- improve DVB-C/T tuning(uno)
- Fix incorrect display of DVB-C/T SNR/AGC(uno)
- Fix high-bitrate problem in CI(uno, needs a FPGA update, New Rev 4.1 FPGA image is at Archive of Vu+)
- Support 3D framebuffer
- Add interface for UI position setup
- Add redundant fpga device at /dev (uno)
- Add ioctl cmd for hdmi_cec(get physical/logical addr.)
- Fix audo mute in pass-through(uno)
- Add interface to set the system code of the remote control(uno)
- Add interface to disable REC VFD icon(uno,duo)
Uno
Duo
Solo
Ultimo
now navigate to
lib/modules/2.6.18-**/extra
depmod -a
20110929
Uno
http://archive.vuplus.com/download/drivers/beta/vuplus-dvb-modules-vuuno-2.6.18-7.3-4.4.3-20110929.tar.gz
http://archive.vuplus.com/download/drivers/beta/vuplus-dvb-modules-bm750-2.6.18-7.3-4.4.3-20110929.tar.gz
http://archive.vuplus.com/download/drivers/beta/vuplus-dvb-modules-vusolo-2.6.18-7.3-4.4.3-20110929.tar.gz
http://archive.vuplus.com/download/drivers/beta/vuplus-dvb-modules-vuultimo-2.6.18-7.3-4.4.3-20110929.tar.gz
