Black Hole Vu+ Duo 1.6.7 Kernel 3.1.1 beta - Uno, Duo & Ultimo
  • pogo2009
    • 45
    Black Hole 1.6.7 Vu+ Uno, Duo & Ultimo Kernel 3.1.1 beta
    THIS IMAGE HAS BEEN COMPILED WITH THE NEWEST LINUX KERNEL AVAILABLE FOR OUR BOXES.
    WARNING: THIS IMAGE USES A NEW FILESYSTEM AND IT IS NOT COMPATIBLE WITH MULTIBOOT OR WITH OLD PERSONAL BACKUP.
    THIS IMAGE HAS TO BE INSTALLED IN THE FLASH.
    THE MOST COMMONLY USED USB TUNER DRIVERS ARE NOW INCLUDED IN THIS IMAGE AND ARE AUTO_DETECTED.(hauppauge win n***, aver volar, aver a867 ecc..)
    THIS MEANS THAT YOU CAN BOOT THE IMAGE WITH THE USB TUNER INSIDE AND IT WILL BE IMMEDIATELY AVAILABLE AND WORKING.
    For this reason the Usb dtt panel has been removed, because it is no longer needed.
    More drivers will be available soon.
    THE WIRELESS management has been changed to use the Vuplus proprietary system plugin and Wpa supplicant have been updated
    to the latest version.
    The HDMI-CEC panel has been removed because Black Hole firmware has switched to native Vuplus Hdmi-Cec implementation.
    So you can now find Hdmi-Cec config in the plugins list.
    This image is totally new inside.
    Please report your tests and opinions.
    Have fun !!
    WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot.
    The image MUST be installed in the flash.
    Black Hole can not support images not installed in the flash.
    This latest version of the Black Hole series has been entirely rewritten and improved in the code for maximum stability and performance.
    Please note that of all images Black Hole now has the best epg system:
    - Integrated OpenEpg
    - Rytec dedicated epg.dat
    - New system epg.dat outside.
    This last feature gives the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
    Community members can then download it from our servers.
    This feature provides other benefits such as:
    Increase download speed of EPG
    Download EPG from any channel
    Schedule the download of EPG decoder even during standby
    Users can customize the providers using Add / Remove function
    Main functions of the buttons on the remote
    OK button = Skin with simple information
    OK button x 2 = Extra Info Skin
    Blue button = Black Hole Blue Panel
    Blue button and then Red button = Black Hole Epg Panel
    Blue button and then Yellow button = System Monitor Panel
    Blue button long press = Extensions
    Yellow button = Time Shift
    Green button = Black Hole Green Panel
    Green button long press = Subservices
    Green button and then Red button = Fast Plugin Setup
    Green button x 2 = Fast Plugin
    Button Red = Start Record
    Addons
    Green button and then Yellow button takes you to:-
    Dedicated server for BlackHole addons
    Download and install additional packages from the Black Hole server
    Infobar / OSD
    Analog Clock Gui
    Channel orbital location
    Advanced Tuner Info: Sr Freq Pol Fec
    Signal SNR, BER
    Infobar picons
    Characteristics of BlackHole Panels
    Blue Panel
    Extra Settings
    Black Hole Cron Manager (Manage schedules)
    OSD Settings (OSD configuration)
    Devices Manager
    Kernel Modules Manager (Kernel module operator)
    Inadyn Settings (Configure Inadyn)
    Swap File Settings (Configure File Swap)
    Hard Disk Settings (Configure Hard Drive)
    Black Hole Mount Wizard (Mount points)
    OpenVPN Panel ( OpenVPN Panel)
    Samba / CIFS Panel ( Samba Panel)
    NFS Server Panel ( NFS server Panel)
    Telnet Panel ( Telnet Panel)
    FTP Panel ( FTP Panel)
    UPnP Client Djmount
    UPnP Server Mediatomb
    Info Panel
    1 - Gui Setting (Gui configurations)
    2 - Service Information (information system)
    3 - About (info)
    Memory (Memory)
    Space (capacity)
    CPU (processor)
    Process (process)
    EPG Panel
    Global settings (global settings EPG)
    Setting Provider (ISP settings)
    Green Panel
    Fast Plugin Setup (Configure quick access to your favourite plugin)
    Fast Plugin (Access your favourite plugin)
    Addons (added)
    Addons Download Manager (Manager for package downloading)
    Installation manual packages (Manual installation of Black Hole packages)
    Manual Install IPK packages (Manual installation of IPK packages)
    Addons Uninstall Panel (Uninstalled packages)
    Black Hole Statistics (See connections, top downloads and more)
    Credits
    Thanks to the group of Beta Testers.
    Thanks to Rytec for providing us with the server with all epg.dat files.
    Thanks to MaxZ4 for Integrated EPG loader.
    Thanks to Skaman for Cross EPG
    Thanks to Lukkino (VDR-Italy) for the source code of OpenTV.
    Thanks to Reinh@rd for the file satellites.xml.
    Thanks to ambrosa (Pli Board) for ready-to-go A867 driver patch
    DISCLAIMER
    THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PUBLISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.
    THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
    LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
    LICENSE (TERM OF USE)
    THE BLACK HOLE IMAGE IS ISSUED FOR THE FREE USE FOR ALL USERS PROVIDED THAT IT WILL NOT BE CHANGED IN ANY WAY AND THAT IT WILL ONLY BE USED FOR LAWFUL PURPOSES.
    ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REVOKE OF THIS LICENSE.
    This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.
    Download VU+ Duo Version Here
    Download VU+ Uno Version Here
    Download VU+ Ultimo Version Here
    VU+ Solo version to follow, (awaiting new bootloader )
    This image requires the latest bootloader installed before flashing!
  • RuberDuck
    • 1724
    be aware these are beta images and should be considered as unstable for that reason.
    • dell_xps
      • 2558
      Download VU+ Ultimo Version Here ?
      • RuberDuck
        • 1724
        yes its not unusual. BH have been releasing ultimo images for quite some time. although vix would never release a image while the hardware is still not publicly available.
        • dell_xps
          • 2558
          Bugger had my hopes up there RD it was released, I was all excited
          to....
          • RuberDuck
            • 1724
            should not be long now, WoS are taking pre-orders for early January as of today. price ?579
            • lincsat
              • 1228
              Apparently the new kernel uses a different file system so the img backup scripts do not work neither do the previous personal backups.
              It is supposed to be faster and better than previously but without the facility to take regular backups, I'm waiting a while
              • RuberDuck
                • 1724
                correct, although andy fixed that issue several revisions ago for the ViX Vu images running the 3.1.1 kernels.
