Vu Uno ViX 2.3 (Linux 3.1.1) 25-12-2011
  • RuberDuck
    • 1724
    UNO
    New VIX Image Vu+ Uno - Build 153
    24/12/2011 - Open ViX 2.3
    From VIX Team
    Enigma: 24-12-2011.
    Enigma Plugins: 24-12-2011.
    GCC Version: 4.4.4
    Kernel Version: 3.1.1
    Drivers: 2011-12-22
    Because of kernel change, you will not be able to perform an online update. A full flash is required for this version of ViX image. But you can use Backup Manager to backup your setting, although any extra plugin will not be reinstalled by the wizard due to the kernel change.
    New Features
    Subtitle structure - Has been changed and now where subtitles are available you will be able to select subtles either via the subtitles Menu or via the Audio Menu then Yellow button
    Where Subtitles are not available you will not be able to bring up the Subtitle Menu or see the Yellow button via the Audio Menu
    This is not a bug but rather a change in the Subtitle structure
    OpenWebIf - this now how has replaced the old WebIf, and as a result it uses the default port of 8088, if you want you can change it back to 80 in the plugin setup.
    Button Mappings
    Short Red** & *** - Show current channel EPG info (ViX Single EPG).
    Long Red*** - Show current event.
    Short Green** & *** - Timers.
    Long Green*** - AutoTimer Timers.
    Short Yellow*** - EPG Search.
    Long Yellow*** - IMDB Database.
    Short Blue - Extensions.
    Long Blue*** - Plugins Menu.
    EPG - Opens ViX EPG.
    Left/Right** - Opens ViX QuickEPG.
    Up/Down** - Open Full Screen Channel List.
    Long Up/Down** - Open Simple TV List.
    TV Button** - Open Full Screen Channel List.
    Long TV Button - Open Bouquets List.
    ** Can be changed in ViX Menu
    *** Can be turned off in ViX Menu
    Special Thanks
    • rytec - for his continued support.
    • zoka.cc for his Picon sets
    • all developers for their plugins used in the feeds of this image.
    • All of the ViX Beta team for their hours of testing and dedication on getting this image working.
    • 'Rob van der Does' & 'belierzz' for their translation work.
    • Silverfox0786 for channel settings and picons.
    Requests
    If anyone is interested in doing any translation work for the plugins and the image itself, please contact either Andy or Sicilian...
    Downloads
     http://www.megaupload.com/?d=ZCFPRBBI
