Vu+ Drivers kernel 3.1.1 and above only.
  • RuberDuck
    • 1724
    as the title says these new drivers by Vu are only to be used on images using the 3.1.1 Linux kernel and above.
    20111222(Needs Image update)
    - Switch to kernel 3.1.1
    - Improve recording(reduce load)
    - Improve vtuner performance
    - Support german remote keyboard(ultimo)
    ( these are already included in the ViX image )
    Duo
    http://www.megaupload.com/?d=NZBDVJBU
    Solo
    http://www.megaupload.com/?d=F42D6CXK
    Uno
    http://www.megaupload.com/?d=W85OD3LU
    Ultimo
    http://www.megaupload.com/?d=ILJ9G5ZA
  • RuberDuck
    • 1724
    - Add security enhancement
    - Reduce FPGA update time(uno, ultimo)
    - Improve recording
    • RuberDuck
      • 1724
      - fix 3d setup in MODE1
      - fix ui position setup problem
      • RuberDuck
        • 1724
        - Add interface to check genuine box
        - Fix recording stop problem.
        Duo
        http://www.megaupload.com/?d=J9ZLMDNH
        Solo
        http://www.megaupload.com/?d=J1HC21HE
        Uno
         http://www.megaupload.com/?d=HKYAID6J
        Ultimo
        http://www.megaupload.com/?d=3PLMBVSX
        • RuberDuck
          • 1724
          20120118 - Fix some DVB-CI modules recognition problem
          • streetball
            • Feb 2012
            guys are the last drivers support the the usb wifi d-link dwa-140 B3?? is there any way in general to see what drivers are included in the set?
            • RuberDuck
              • 1724
              These are hardware drivers for the receiver it self. all the necessary changes are within the changelog released with every driver release. Drivers for DVB-T USB sticks are usually included within the linux kernel or available for download vai the images own feeds.
              • RuberDuck
                • 1724
                This is the entire changelog for the hardware drivers since the box was released.
                http://archive.vuplus.com/download/drivers/log.txt
                • RuberDuck
                  • 1724
                  - Add support for dual S2 Tuner(uno, ultimo)
                  - Fix HDMI recognition problem on some TVs(uno, ultimo)
                  - Fix TS playback problem
                  • dell_xps
                    • 2558
                    Backed up old drivers this time :-), loaded and rebooted no probs RD :-)
                    • RuberDuck
                      • 1724
                      - Improve TS playback
                      - Improve Graphic 2D acceleration
                      - Fix Russian VFD display(duo, uno)
                      - Fix High/low symbolrate channel scan problem.(Uno, Ultimo : Need FPGA Update)
                      -- UNO : Archive of Vu+
                      -- ULTIMO : Archive of Vu+
                      - Fix EOS detection problem in media playback
                      - Enhance Security
                      Download via
                      • dell_xps
                        • 2558
                        Cheers RD :-)
                        Did the FPGA Update also :-)
                        • RuberDuck
                          • 1724
                          - Fix tuner lock fail problem(ultimo)
                          - Enhance security
                          - Add bcm7356 support
