VU+ UNO New Image Help Needed
  • pobreton
    • Oct 2012
    • 4
    Hi, I'm trying to flash latest VIX image to my UNO, do I need to update or install a bootloader first??? Please keep it simple. Cheers
  • benny/9
    • 1964
    no mate,the latest bootloader is in the image
    Please Read Carefully!
    • pobreton
      • Oct 2012
      • 4
      Thanks benny/9, It couln't be simpler than that! Cheers
      • freck
        • 1076
        Dont have a usb stick with any bootloader come within 20 feet of an Uno
        Bricked mine a few weeks back with a duo bootloader
        Freck
        • mdt
          • 3034
          stick blackhole on it m8, best image for the vu+ boxs by far imo,regards mdt
          • pobreton
            • Oct 2012
            • 4
            Sound's interesting
            Thanks Andrew, But how easy is it? will it mess up any other settings, FGPA etc.
            • Bbigfoot
              • Apr 2011
              • 9
              Vix
              Hi pobreton.
              I have a VU+ Uno with the latest
              Openvix image (381).
              It's the best image iv had.
              When you have downloaded
              Vix (3.0. 381) or any other
              3.0 Vix image, open its yellow
              folder it will say (vuplus)
              Now plugin a USB stick into PC,
              right cilck (vuplus) then up to
              (Send To), and send it to your
              USB stick.
              Now Double click on (vuplus) it
              will turn into (uno) right click
              on (Uno) and send that to your USB stick.
              Go to your Uno, turn off at the back, plugin
              to the front USB on your Uno the USB stick.
              Turn Uno on with back switch.
              Uno will say New Update, click on left
              switch on Uno to start Update.
              Once Open vix is installed their is a
              green Icon buton in the info bar.
              If their is a new version of Vix it
              will flash green,
              goto Munu-Setup-Softwae Update
              to upload new version.
              All your setting will also be loaded back in
              including you (CCCam cfg file).
              BF.
              • mdt
                • 3034
                it wont mess up your settings, just do a back-up first and if you dont like it you can always go back,regards mdt
                • pobreton
                  • Oct 2012
                  • 4
                  Originally posted by Bbigfoot
                  Hi pobreton.
                  USB stick.
                  will flash green,
                  BF.
                  Hi BF,
                  Thanks, your clear, easy to follow instructions did the trick. I flashed build 381 and then updated to 398. However I lost my cam, cccam Manager was empty, I downloaded CCcam 221 through TS-Panel, it is selected and active but I can still only receive FTA, any tips?
                  Pobreton
