Sky uk ready BlackHole Vu+ Duo v. 1.6 - Backup
  • RuberDuck
    • 1724
    Sly uk ready BlackHole Vu+ Duo v. 1.6 - Backup
    Button Mappings
    OK button = Skin with simple information
    OK button x 2 = Extra Info Skin
    Blue button = Black Hole Blue Panel
    Blue button and then Red button = Black Hole Epg Panel
    Blue button and then Yellow button = System Monitor Panel
    Blue button long press = Extensions
    Yellow button = Time Shift
    Green button = Black Hole Green Panel
    Green button long press = Subservices
    Green button and then Red button = Fast Plugin Setup
    Green button x 2 = Fast Plugin
    Button Red = Start Record
    Addons
    Green button and then Yellow button takes you to:-
    Dedicated server for BlackHole addons
    Download and install additional packages from the Black Hole server
    Whats New ?
    This image is Sly uk ready with Oscam and N line in CCcam.cfg for updating entitlements.
    CCcam 2.1.4
    CCcam 2.1.3
    Oscam 5210 ( thanks to new2linux for the start/stop script )
    Latest CCcam Channel info
    Latest CCcam Providers
    SGTFlipFlop ENiGMA2 07.05.11 (Multi)
    SGTFlipFlop ENiGMA2 07.05.11 Picons (usr/share/enigma2)
    Cooltvguide Coolman V3.0 ( setup for Red button )
    Shoutcast
    tspanel 1.4
    Multi Quickbutton
    Cron reboot set for 08.00
    PASSWORD:
    vuplus
    USB
    http://hotfile.com/dl/117485487/c383c3c/blackhole_1.6_sky_ready_USB.rar.html
    NFI
    http://hotfile.com/dl/117486161/5516d42/blackhole_1.6_sky_ready_NFI.rar.html
  • dell_xps
    • 2558
    Rubber Duck whats yer views on this ?
    Better to stick with vix image or give this a go ?
    • RuberDuck
      • 1724
      i would personally stick with vix but i am severely biast, i do know a fiar few people who swear by these images however, and you never know unless you try it for your self.
      • cactikid
        • 12017
        i think i had black hole on mine before and changed to vix,i presume this is more for the uk market than the republic of ireland or might it work with an adjustment?
        • RuberDuck
          • 1724
          this image has been specifically setup for use with sky uk. so if you are using sky them it should work fine weather your in the roi or the uk.
          • drahcirk03
            • May 2011
            • 13
            no cam
            bin trying for 5 hours to get into cam, at bottom of info bar ,it says cccam 2.1.4. but i just cant get into it, after downloading the above file,
            • RuberDuck
              • 1724
              i dont personally use this image i use VIX. my self.
              • drahcirk03
                • May 2011
                • 13
                has the vix got a cccam in?
                • RuberDuck
                  • 1724
                  not by default no, but it takes seconds to install cams and have them running
                  • drahcirk03
                    • May 2011
                    • 13
                    i load in the cam, it keeps saying ,please wait ,starting cccam 1.2.4. and thats it ,zilch,
                    • cactikid
                      • 12017
                      my vix has cccam2.2.1 and mg1.35a running,you need to stop one to use another or conflict may occur
                      • madmanuk
                        • 202
                        cant find the download lads,Would this be ok to use on a clone vu+duo.
                        • DOUGALMCD
                          • May 2011
                          • 3229
                          Download not there answer to your question is yes but why old image?
                          • madmanuk
                            • 202
                            i just wanted an image with oscam/cccam for vu+duo clone and this is the only one i could see that looked ok,Is there an uptodatet one mate.
                            • mdt
                              • 3034
                              put blackhole 1.7.2 on your box then add oscam/c**am 2.13 uk ipk on and your done,regards mdt
