ViX Team VU+ Duo OE3.0 Release
  • andy211081
    • 575
    #16
    Originally posted by weepaul51
    whats the minimum internet speed needed for cardshare
    dont talk about cardsharing on here buddy, google is your friend with CS related info but in the past i had a 2meg broadband and had no issues when using a box. obviuolsy that was me not using the internet for downloading or anything
    Ladies and Gentlemen, this is your captain speaking. I have the only gun on board. Welcome to Con Air.
    • RuberDuck
      • 1724
      #17
      OpenViX 3.0-268 AVAILABLE NOW
      e2-git changelog
      openvix: build 268
      [EPGSearch] add support to search for currently playing media file.
      openvix: build 267
      openvix: build 266
      Merge remote-tracking branch 'pli/master'
      [SoftwareUpdate] fix possible BSOD
      [SoftwareUpdate] fix the package count.
      InputDeviceSetup: add option to select what type of remote control to use ( on supported platforms only )
      [Translations] DE update thanks Ralf.
      fastscan: do not store the default audio pid in the cache
      servicedvb: fix audio pid cache entry
      cahandler: cache PMT sections
      openvix: build 265
      true item's number in movielist
      [translations] nl update
      MovieList: Autotagger collects sentence parts
      PliExtraInfo: use evNewProgramInfo to determine when to read FEdata ( we can asume zap is finalized on this event )
      servicedvb: add new event evNewProgramInfo
      PliExtrainfo: don't update FEdata on iPlayableService.evUpdatedInfo
      frontend: do not attempt to read tuner status while tuning
      eDVBFrontend::getFrontendStatus: reduce the number of syscalls
      frontend: get rid of duplicate frontendinfo enums
      MovieSelection: Simplify playlist handling
      HdmiCec: add wakeup on 'TV physical address report' option
      HdmiCec: wakeup on 'activity' should ignore standby command
      oe-git changelog
      openvix: build 268
      openvix: build 267
      Merge branch 'master' of github.com:oe-alliance/oe-alliance-core
      openvix: build 266
      update usb-modeswitch to 1.2.4  the version 1.2.3 is down
      [gigablue] update driver gb800 and gbquad to 10.09.2012
      [gigablue] temp bump PV to revert old drivers.
      [dreambox] add missing modules
      remove 'OPENPLI_FEATURES' as it should not be used in oe-alliance.
      fix Dreambox image build, add fan control for DM800se, add dtsdownmix lib, add dvd feature for dm7020hd and dm8000
      dvb-c blindscan utils missing in image
      openvix: build 265
      [gigablue] push build drivers
      [ocram-picons] remove packages, as he now supplies a feed.
      [gigablue 800] on request rollback drivers to 31.08.2012
      [openaaf] remove vps from image build
      images can be downloaded directly from the openvix server
      or via a online update
      menu> setup> software update.
      or via a telnet session with the following command
      init 4 && opkg update && opkg upgrade && init 6
      • meggiedude
        • May 2012
        • 215
        #18
        I'd be very cautious about loading anything via the online update options on the box. Went to the latest version today (forget the version number , 308? 309?) when the feeds were actually working for the Duo (a rare thing it seems at the moment).
        It loaded and then completely scewed the mount tables.
        Noticed that all the picons were gone and no ability to see recorded Progs on Hard drive.
        No mounts for USB or HDD, and core dumped every time it was set manually.
        So no ability to restore from backup on the HDD.
        Had to flatten & rebuild v294 via USB and then restore settings when the HDD mounts came back.
        It appears the feeds are in a right old pickle for the Duo at the moment. Down again tonight.
        Put me right off upgrading OTA.
