BlackHole Vu+ Solo v. 1.6 - Graphics preview
  • RuberDuck
    • 1724
    This Release Includes:
    - Update drivers 20110429
    - Update crossepg svn 292
    - New: added category bootlogo in addons
    - New New New: added FULL SCREEN PREVIEW of skins and bootlogo
    - New: snr working in usb tuner (most sticks supported)
    New: add AC3+/DDP support (experimental)
    WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot.
    The image MUST be installed in the flash.
    Black Hole can not support images not installed in the flash.
    This latest version of the Black Hole series has been entirely rewritten and improved in the code for maximum stability and performance.
    Please note that of all images Black Hole now has the best epg system:
    - Integrated OpenEpg
    - Rytec dedicated epg.dat
    - New system epg.dat outside.
    This last feature gives the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
    Community members can then download it from our servers.
    This feature provides other benefits such as:
    Increase download speed of EPG
    Download EPG from any channel
    Schedule the download of EPG decoder even during standby
    Users can customize the providers using Add / Remove function
    Main functions of the buttons on the remote
    OK button = Skin with simple information
    OK button x 2 = Extra Info Skin
    Blue button = Black Hole Blue Panel
    Blue button and then Red button = Black Hole Epg Panel
    Blue button and then Yellow button = System Monitor Panel
    Blue button long press = Extensions
    Yellow button = Time Shift
    Green button = Black Hole Green Panel
    Green button long press = Subservices
    Green button and then Red button = Fast Plugin Setup
    Green button x 2 = Fast Plugin
    Button Red = Start Record
    Addons
    Green button and then Yellow button takes you to:-
    Dedicated server for BlackHole addons
    Download and install additional packages from the Black Hole server
    Infobar / OSD
    Analog Clock Enigma2
    Channel orbital location
    Advanced Tuner Info: Sr Freq Pol Fec
    Signal SNR, BER
    Infobar picons
    Characteristics of BlackHole Panels
    Blue Panel
    Extra Settings
    Black Hole Cron Manager (Manage schedules)
    OSD Settings (OSD configuration)
    Devices Manager
    Manager Kernel Modules (Kernel module operator)
    Inadyn Settings (Configure Inadyn)
    Swap File Settings (Configure File Swap)
    Hard Disk Settings (Configure Hard Drive)
    Black Hole Mount Wizard (Mount points)
    OpenVPN Panel ( OpenVPN Panel)
    Samba / CIFS Panel ( Samba Panel)
    NFS Server Panel ( NFS server Panel)
    Telnet Panel ( Telnet Panel)
    FTP Panel ( FTP Panel)
    Usb Tuner Panel
    UPnP Client Djmount
    UPnP Server MediaTomb
    Info Panel
    1 - E2 Setting (Enigma2 configurations)
    2 - Service Information (information system)
    3 - About (info)
    Memory (Memory)
    Space (capacity)
    CPU (processor)
    Process (process)
    EPG Panel
    Global settings (global settings EPG)
    Setting Provider (ISP settings)
    Green Panel
    Fast Plugin Setup (Configure quick access to your favourite plugin)
    Fast Plugin (Access your favourite plugin)
    Addons (added)
    Addons Download Manager (Manager for package downloading)
    Installation manual packages (Manual installation of Black Hole packages)
    Manual Install IPK packages (Manual installation of IPK packages)
    Addons Uninstall Panel (Uninstalled packages)
    Black Hole Statistics (See connections, top downloads and more)
    Credits
    Thanks to the group of Beta Testers.
    Thanks to Rytec for providing us with the server with all epg.dat files.
    Thanks to MaxZ4 for Integrated EPG loader.
    Thanks to Sandro Cavazzoni for Cross EPG
    Thanks to Lukkino (VDR-Italy) for the source code of OpenTV.
    Thanks to Reinh@rd for the file satellites.xml.
    Thanks to bigroma (***************** board) for rt3070 patches.
    Thanks to pieteng for AC3+/DPP patches
    DISCLAIMER
    THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PULBISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.
    THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
    LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR IILEGAL PURPOSES SUCH AS CARD SHARING.
    LICENSE (TERM OF USE)
    THE BLACK HOLE IMAGE IS ISSUED FOR THE FREE USE FOR ALL USERS PROVIDED THAT IT WILL NOT BE CHANGED IN ANY WAY AND THAT IT WILL ONLY BE USED FOR LAWFUL PURPOSES.
    ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REWOKE OF THIS LICENSE.
    BlackHole-1.6-vusolo_usb.zip (45.24 MB)
    http://www.multiupload.com/MYOTBRBRFG
    BlackHole-1.6-vusolo_nfi.zip (45.24 MB)
    http://www.multiupload.com/23386X6U22
  • atef 0
    • May 2011
    Thank you Regards
    • atef 0
      • May 2011
      Thank you Regards
