ViX Team VU+ Solo Image v2.2.100 - 21/07/2011
  • RuberDuck
    • 1724
    New VIX Image VU+ Solo - v2.2.100
    21/07/2011 - Open ViX 2.2.100
    Based on Open PLi 2.0
    From VIX Team
    Enigma: 21-07-2011.
    Enigma Plugins: 21-07-2011.
    GCCVersion: 4.4.4.
    Kernel Version: 2.6.18.
    Drivers: 20110708.
    If you wish to perform an online update, then you will be able to upgrade your v2.2 image to v2.2.1 via the online functions. This full image is available for those who do not have online functionality on their box, or wish to perform a full reflash...
    Team ViX Enchancements
    New Features
    BackupManager - Lets you create scheduled backups of your system files (not full Image like Image Manager).
    RestoreWizard - This a wizard that detects and restores you backup (created with BackupManager), with option to restore your extra plugins.
    ImageManager - Major code rewrite, now handled by Job task, view progress of image creation in extension list (blue button)
    ViX Menu - Added PackageManagement & Software Update, so SoftwareManager is now not needed. It is also now translatable into different languages.
    NetworkInadyn - Add new network setup screen Inadyn.
    OScam/CCam Info - Added options to show in Extension List. (the Menu item will now only show IF the softcam is installed).
    OnlineVersionCheck - Added option to disable online check by setting check value to '0' and set a maximun timer to 48 hours.
    Recording List - Added a new option in MovieList Settings to use a "Slim" list like the "Slim" Channel slection screen.
    EPG Graphical - This is now in core, no longer a plugin (was ViXEPG), added the option to show Bouquets on launch.
    EPG Menu - Add Load/Save item, this allow you reload/save the EPG cache.
    E2-Plugin's - Updated all to plugin's to the latest GIT from PLi.
    ZAP Timer - This will create a zap timer (rather than a recording timer) for the selected event in the EPG/Single EPG etc. To activate this, select the event from the EPG, and do a long button press on the record button. This is a non-configurable timer, so will use all defaults, and just set the record to a zap, rather than a record. When adding a zap timer, the clock icon will show on the previous event. This is to do with the pre-start timer.
    Fixes
    SwapManager - Code cleanup, for better activation/detecion.
    About Screen - Updated infomation screen, better layout, more information. VFD now shows image version.
    EPG Search - Fix a bug where the yellow button just opened a blank EPGSearch screen instead of actually perfoming a search on the current event. Also, added 'Show History' to long yellow button press whilst in EPGSearch.
    EPG Cache - Updated so now it does not require 2 reboots in order to use new location.
    EventView - Fix GS on opening Similar List.
    Network Link State - fixed Vu+ machine network link state.
    PluginBrowser - fix it not installing picons.
    ShoutCast - Fixed plugin.
    SoftcamManager - Add Timercheck for OScam to support no username or password in Webif, fix GS when pressing coloured buttons, if no softcams installed, also code clean up.
    Translation - Updated NL language files.
    [B]Permantent TimeShift fix and embed PTS.
    Updated KeyMap - Fixes a few MoviePlayer remote control issues.
    ViX HD skin - PNG fix for selected items in lists, Tweaked the Jobview screen, 'New Online Version' icon now flashes to remind you of an update.
    VIXEPG fix - The < > keys for jumping +/- 1 day.
    NetworkBrowser - fix GS when creating CIFS mounts.
    RemoteSetup fix GS when showCoolTVGuide is selected.
    Button Mappings
    Short Red** & *** - Show current channel EPG info (ViX Single EPG).
    Long Red*** - Show current event.
    Short Green** & *** - Timers.
    Long Green*** - AutoTimer Timers.
    Short Yellow*** - EPG Search.
    Long Yellow*** - IMDB Database.
    Short Blue - Extensions.
    Long Blue*** - Plugins Menu.
    EPG - Opens ViX EPG.
    Left/Right** - Opens ViX QuickEPG.
    Up/Down** - Open Full Screen Channel List.
    Long Up/Down** - Open Simple TV List.
    TV Button** - Open Full Screen Channel List.
    Long TV Button - Open Bouquets List.
    ** Can be changed in ViX Menu
    *** Can be turned off in ViX Menu
    Known Bugs
    • Second subtitles in AVI, MP4 etc often need a stepskip to enable them to show up.
    • Shoutcast has no genrelists and menu is not working.
    Special Thanks
    • rytec - for his continued support.
    • PLi Team for their great base image and allowing us to use it.
    • zoka.cc for his Picon sets
    • Coolman and all other developers for their plugins used in the feeds of this image.
    • All of the ViX Beta team for their hours of testing and dedication on getting this image and DTT working
    Screenshots
    About Screen:
    ViX Menu:
    Downloads
    http://www.mediafire.com/?ox37q3oiw110qit
  • COVENANTS LAND
    • 15
    Hello Guy's
    could I ask for some advice I have a VU+ solo with TVI installed this is ok but I would like to install vix or black hole what one is best and how do I install it ?
    also can I brick the VU+ by messing with it ?
    thanks guys
    COV
    • RuberDuck
      • 1724
      i'd biast towards VIX as i'm a beta tester for them and a admin on theor forum but i'd say try a few images to see which you like. as for flashing the box it's very easy to do with a USB stick and i'm sure there is a tutorial here some where. as for bricking the box. yes and no. these boxes are almost indestructible but always read the instructions and ask questions where you need to and you will be fine.
      • COVENANTS LAND
        • 15
        I've just installed BH
        but I've now downloaded VIX and I put it on as soon as I can
        thanks for taking time to help
        COV.
        • dell_xps
          • 2558
          Better with Vix image m8, as RD sais indestructable....
          as I found out the other day :-)
          • COVENANTS LAND
            • 15
            Help Please I can't change the black hole I tried for 4 hrs last night. can someone tell me the best way to get rid It's driving me mad I must be doing something wrong
            Cov.
            • COVENANTS LAND
              • 15
              I've now been messing with black hole all day I keep getting a green screen and it restarts could somebody tell me how to remove black hole. I can't format my usb linux I've also tried ftp to my box I've also tried DCC but I've no idea what to do I think I've F*CKED UP big time
              cheers Cov
              • dell_xps
                • 2558
                Put vix image on usb stick, unzip it, copy the main folder and sub folders across to your usb stick, power off your vu duo, stick usb in front slot of vu duo, power up, check out the front display, should tell you when its finished installing.
                • COVENANTS LAND
                  • 15
                  Thanks Dell your a star and yes indistructible comes to mind
                  • dell_xps
                    • 2558
                    No probs m8.
                    • COVENANTS LAND
                      • 15
                      Guy's I've now got VIX 2.2.100 running perfect also 2.2.1 cam but my cccam.cfg can't be found am I putting it in the right place sorry for sounding like a tool
                      I've Put it in var/ect but it's not working
                      Cov.
                      • dell_xps
                        • 2558
                        No m8, root folder then the etc folder, not var then etc folder.
                        I answered your other thread last nite about this :-)
                        • RuberDuck
                          • 1724
                          Cov.
                          Var/Etc is for enigma 1 based receivers you are now using a enigma 2 based receiver so the folder now is just /ETC
                          • COVENANTS LAND
                            • 15
                            Up and running you two guys are brilliant many many thanks
                            • dell_xps
                              • 2558
                              No probs, glad you are up and running :-)
