sharing solo feed another room
  • Rodbouy
    • Jul 2010
    • 1320
    #16
    Aye, it was me purely thinking aboutmy own setup and the magic eye was purely for control and no picture.
    • cactikid
      • 12017
      #17
      bit lost as to the aerial from roof info.
      • homer41
        • 207
        #18
        yh thats where i was lost also on the tv link website it says to have a tv aerial input into the rf mod, what the hell would this help me achieve haha
        • digicon
          • 8261
          #19
          Well for a start hats the model i use sometimes on installs it lets you input 2 sources and combine them so you have 1 single output.
          so in your case your solo would go into the Scart connector and also if you wish you can put the aerial into the aerial in socket. The modulator combines the signal like a sky box would do feed that single signal into the TVlink Plus and upstairs you not only have your solo output but freeview also.
          Regards
          • cactikid
            • 12017
            #20
            gotcha now yes remember a dish and aerial feed from roof to room with one cable feed.
            • homer41
              • 207
              #21
              ok mate that is very helpful to know, some excellent help on here very much appreciated, on the tv link plus it has two out puts isit necessary to use these both?
              • digicon
                • 8261
                #22
                No need really as only one has the DC pass for the Magic eye, RF1 out normally feeds back into the TV where your equipment is and RF2 Out (Magic eye) feeds where ever you want it to go.
                • homer41
                  • 207
                  #23
                  ok mate thats good to know, im thinking of running the rf out in to my distributor, and then it splits to loads of rooms, but im only interested in getting into upstairs bedroom, so it will go via the distributor that shouldnt cause a problem would it?
                  • digicon
                    • 8261
                    #24
                    It will if your distribution box does not have DC pass through for the magic eye, although if your running RF1 through it this wont matter as there is no DC pass on RF1 only RF2 has the DC Pass for a Magic Eye.
                    • homer41
                      • 207
                      #25
                      ok mate and then the rf in the room upstairs connect up to the tele using a tv link magic eye and its should work?
