VU Solo clone
  • setfiretorain
    • Jul 2010
    • 934
    VU Solo clone
    I just purchased a VU solo clone from nextbay, It all come and is all okay as far as the eye can see.
    I have tried to load in Vix 2.3 via USB when booting and nothing happens, At the moment I have manually Intalled CCcam from a Tar file and Scanned in, Its currently on blackhole 1.6 ( Or something like that )
    I've tried to update with RJ cable and my PC has no connection to do so, I tried to update the Kernal then update to Vix 2.3 but no joy there either as it just booted straight up with no update etc.
    I would basicly like it with Vix OR Even what its on at the moment, I just need to get the simple Sgt Flip Flop installed and I'm laughing.
    Any help appericiated.
    Regards
    '"If you can't make decisions in life, you're a bloody menace. You'd be better becoming an MP!"
    Quote from Mr Shankly, YNWA, JFT96
    Sat Boxes
    Spiderbox 7000 HD with " gift "
    Dreambox 500s.
    Dishes
    1.1 Motorised triax satellite dish single LNB.
    Sky minidish self fitted.
  • setfiretorain
    • Jul 2010
    • 934
    All Done!!
    Regards
    Sat Boxes
    Dreambox 500s.
    Dishes
    • RuberDuck
      • 1724
      so what was up with it ?.
      • setfiretorain
        • Jul 2010
        • 934
        I still can't update, I just running on blackhole 1.6 ( or something like that ) - With CCcam 1.2.3 and Sgt Flip Flops.
        Regards
        Sat Boxes
        Dreambox 500s.
        Dishes
        • RuberDuck
          • 1724
          Its very likely then that you have a V1 clone which needs to be patched to take kernel 3.1.1 images.
          • potrobber
            • Mar 2010
            • 493
            setfire m8
            can i ask what color the controller is with your box and does it have the vu+ at bottom of controller
            also at the rear of your box or underneath see if there is a small v2 sticker if not its version 1 box
            to do the update you need a com port on the computer to do it
            no usb to com connector will work on these just com to com port
            the last solo,s i got had bh1.72 on them and v2 sticker underneath with black controllers same as duo with vu+ at bottom but have read some getting them with white controllers or controllers with no vu+ on them
            • setfiretorain
              • Jul 2010
              • 934
              It has VU+ On the bottom of the controller, the controller is black and it also has a V2.0 sticker underneath.
              Regards
              Sat Boxes
              Dreambox 500s.
              Dishes
              • RuberDuck
                • 1724
                Then it is a V2 clone and as such should already have been patched with the IC security update to accept Linux 3.1.1 kernel based images. I would personally flash the newest bootloader to the box as it cant hurt matters plus it only takes a few seconds, also try a different USB stick as they are known to be a bit temperamental with sticks they will accept for flashing images.
                • cactikid
                  • 12017
                  i had the same problem with my original solo and i got the usb with the duo and it did not work on the solo ,tried 3 and 1 worked.
                  • mdt
                    • 3034
                    Regards
                    did you try a different usb stick like i suggested in my pm?? regards mdt
                    • setfiretorain
                      • Jul 2010
                      • 934
                      Its all running perfect at the moment guys, On the OLD BH image, However will deffo be trying new stuff next week.
                      Regards
                      Sat Boxes
                      Dreambox 500s.
                      Dishes
