Solo CFE downgrade from 2.0 to
  • cracket
    • Dec 2011
    Did anybody succeeded with downgrading from CFE 2?
    Before I upgrade to kernel 3.1.1 and cfe 2 (Build date Wed 18 May 10:18 50 2011) I would like to check if it's possible to get back from this upgrade.
    My current CFE 2.27 has build date Thu Feb 18 20:58:28 2010
    How can I change layout of current partitions for solo? Is there any way to recover if CFE is wiped out from flash?
    How BCM knows where to find CFE?
  • RuberDuck
    • 1724
    if you destroy the bootloader you destroy the receiver. and to be honest why would you want to downgrade the bootloader ? as Vu bootloaders are fully backwards compatible with all previous images regardless of the kernel in the image.
    • cracket
      • Dec 2011
      I don't want to destroy bootloader, only wanted to find out some more information about vu - because most of information are chaos, not true knowledge. Haven't found good site about system itself (hardware of bcm) - and without knowing it better it's difficult to just upgrade bootloader just like that.
      There are more solutions for problems with system, not only bootloader upgrade - moving root filesystem to external/network device, customizing filesystem to fit 48MB, mixing new kernel with old small root etc..
      Bootloader upgrade is last resort, and even when suggested by vendor-the only reason is bug that old one cannot flash root>48MB? WTF?
      Why with cfe upgrade there is no jtag details?
      I know that there are many people across forums who barely know how to put file to pendrive, and upgrade "box", but there are some others who want to know a little bit more about their own device.
