Security IC update without rs232 board
  • hossen
    • May 2012
    • 4
    Hi,
    Is it possible to connect null modem directly to vu solo for Security IC update,as i don't have 232 board.
    Thanks.
    Regards
    hossen
  • benny/9
    • 1964
    Originally posted by hossen
    Hi,
    Thanks.
    Regards
    hossen
    no mate the rs232 board changes the wiring circuit and if you
    just use a null modem cable you could kill the box
    also just be aware you also need a computer with a fix
    9 pin comport fitted you cant use a usb to serial converter
    they dont work with the box and rs232 board
    have thought of asking on the ferrari forum if anyone knows
    where you can buy a rs232 board
    Please Read Carefully!
    • hossen
      • May 2012
      • 4
      Hi benny/9,
      Thanks for your quick reply.
      I will follow your advice.
      I did make a search on the net and eBay but could not find that rs232 board.
      Hopefully,someone may lend it to me.
      K.Regards
      • benny/9
        • 1964
        if your good with electronic's you can make one up
        take a look at the attachment
        • hossen
          • May 2012
          • 4
          Thanks benny/9, but i prefer not to try.
          k.Regards
          • asad5150
            • Oct 2008
            • 185
            i may have a spare one with cable. wil hve to look tomrow and let u knw
            • hossen
              • May 2012
              • 4
              rs232 board
              Hi asad515,
              Greatly appreciated if you could find it and lend it to me.
              Thank you
              Kind Regards
              Hossen
              • livdogred
                rs 232 board circuit
                can i download the attached circuit of the rs232 board so that i can build it. I will post the results when ii finished
                • benny/9
                  • 1964
                  as you can see from the diagram posted earlier
                  the small rs232 board for the vu clone boxes
                  does'nt have anything but circuitry on it. this
                  board changes the pin connection to work with
                  the vu boxes, and it appears to only use 4 pins
                  and they are these
                  ground goes to ground
                  pin 4 goes to pin 3
                  pin 5 goes to pin 5
                  pin 6 goes to pin 2
                  and i cant see why a null modem cable converted
                  to the board settings wont work without the rs232 board
                  • livdogred
                    10x benny/9 as i said i am going to make one myself if succeeded i will let you know.
                    • radek12
                      • Sep 2012
                      Do you need the rs232 board for reviving both original vu+ and clones, or only clones?
                      • mdt
                        • 3034
                        just clones m8 originals dont need/use a security chip. regards mdt
                        • livdogred
                          rs 232 board
                          hi i have just found that the rs 232 board can only be used for clone ferrari and cannot be used for other clone other than ferrari.Those clone vu+solo that came without the rs 232 board cannot ubdate it,is this true because mine came without an rs 232 board.
                          • livdogred
                            • livdogred
                              rs232 board
                              These two images shows the difference between a Ferrari clone which have came with the rs 232 board.The other image shows a clone other than ferrari.From what i have found those clones that have no rs 232 board are not supported and i dont know if they can make the security IC ubdate.
