Audio Narrator
  • setfiretorain
    • Jul 2010
    • 934
    Audio Narrator
    Hey - getting annoying now - Box is going to narrator on any channel that has it as an option - Have to hit audio and change it myself.
    Is there anyway to preset it to english so I don't have to keep changing it - Not a HUGE issue - just kind of annoying.
    Regards
    Sat Boxes
    Dreambox 500s.
    Dishes
    Sky minidish self fitted.
    Have you set your preferred audio Language in the menu section, there you can set up to 5 audio preferences something like 1. english and then 2. original should sort it but you still may find the odd one that requires a manual change
    • setfiretorain
      • Jul 2010
      • 934
      Where is that, I don't have a option for that - Did when I was on vix - But on BH atmo.
      Regards
      Sat Boxes
      Dreambox 500s.
      Dishes
      • cactikid
        • 12017
        what no setup settings?dont power off or you will be starting again .
        the vu duo i turn the switch at back
        • dell_xps
          • 2558
          There is no rear on/off button on a solo :-)
          • cactikid
            • 12017
            yes forgot i moved boxes around.
            • setfiretorain
              • Jul 2010
              • 934
              Don't quite get what you mean to be honest mate - confusing me here .
              Just want to get the narrator off and english on perm, so I don't have to change it every single time!
              Regards
              Sat Boxes
              Dreambox 500s.
              Dishes
              • cactikid
                • 12017
                use audio button on remote and change stream,if you are on foreign sats you may not have that option.
                • setfiretorain
                  • Jul 2010
                  • 934
                  I know how to do that - Is there anyway to make that permanent tho, save changing each time ?
                  Regards
                  Sat Boxes
                  Dreambox 500s.
                  Dishes
                  • Diddly
                    • Aug 2012
                    Hi I'm new to the forum but was looking for an answer on the net as I have the same problem with narrated audio on my Vu+ Ultimo running latest black hole and in the end found out how to change it permanently!
                    Here it's;
                    MENU>SETUP>SYSTEM>A/V SETTINGS>
                    Make sure Dolby Digital Default is set to YES and Dolby Digital Downmix is set to YES
                    And that's it no more narration nightmare!
                    • DOUGALMCD
                      • May 2011
                      • 3229
                      If I remember correctly you still have to sort out music channels audio.
