hi i have been trying to initialize a usb stick in the solo for epg only, the problem is it gets to 99% then i get the failed message, i have tried 7 different ones today without any luck, has anyone got this to work and what make of usb stick are you using...thanks in advance
solo epg what usb stick
format your stick in your pc/laptop then install your stick, mount it to media/usb and restart your box,regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W -
For Vix Format stick in computer>Insert into rear of solo>switch off then back on>press blue button go to vix>mount manager>set up mounts green button>left or right till you select media usb then save. Then menu>set up>system>epg>settings then select epg location to media usb press ok to save. Then go to crossepg>configure>set scheduled daily download>exit>select update rytec providers>update xepdb providers>exit after they update>select open tv providers>make sure you tick the one you want> To save press green>exit press blue button>select crossepg downloader and don't interrupt. hthComment
thanks for your help i got the box already set up but the person i got it from sent me a file called vu folder inside is vu solo in that is
root_cfe_auto.jff
kernal_cfe_auto
is this what i need to put on usb stick to reflash it (can no longer contact the person who flashed it)..Comment
root_cfe_auto.jff
kernal_cfe_auto
the folder should be called vuplus and inside that is vusolo and inside that is cfe/jff ect. put the vuplus folder into the usb stick and shove it in the front slot with the stb switched off at the back then switch the box on and leave it alone untill you have a flashing green led on the front. i always give it 15mins to be sure. when its finished remove stick and re-boot box,regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
